Ir para o conteúdo principal
Toshiba Satellite C660 Keyboard Replacement
ZFix
ZFix e 3 outros colaboradores
Última atualização em April 23, 2023
5 - 10 minutos
Muito fácil
Guia colaborativo
Keyboard replacement for Toshiba Satellite C660 - Video tutorial:
O que você precisa
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. Toshiba Satellite C660 Keyboard Replacement, Keyboard replacement: passo 1, imagem 1 %32 Toshiba Satellite C660 Keyboard Replacement, Keyboard replacement: passo 1, imagem 2 %32
    • Remove the charger and the battery.
  2. Toshiba Satellite C660 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite C660 Keyboard Replacement: passo 2, imagem 2 %32 Toshiba Satellite C660 Keyboard Replacement: passo 2, imagem 3 %32
    • After removing the narrow plastic lid, you will see 4x Phillips screw.
  3. Toshiba Satellite C660 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite C660 Keyboard Replacement: passo 3, imagem 2 %32 Toshiba Satellite C660 Keyboard Replacement: passo 3, imagem 3 %32
    • Pick up the keyboard and disconnect the flex cable.
  4. Toshiba Satellite C660 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite C660 Keyboard Replacement: passo 4, imagem 2 %32 Toshiba Satellite C660 Keyboard Replacement: passo 4, imagem 3 %32
    • Now connect the new Keyboard. It was very easy. :-)
Conclusão
12 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
194.093 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 327
Autoria de 1.699 guias
5 comentários
Hi there, Thank you very much.. please help me .. i broke that white plastic draw beneath the keyboard cable while was pushing it away to take the cable off .. what to do please?
Reef - Responder
You can put a piece of plaster tape to attach the tablecloth with the plug. Take a piece of chatertone (electric tape) to avoid short circuiting.
Hyperion - Responder
Abdelhamid Fathy Amer - Responder
Great stuff, I actually fixed my ancient and loved laptop, why is it loved? I hate Win 10 and have a new ASUS which is ace and super fast, but it is still Win 10 that I cannot get to grips with, but cannot restore the ASUS with Win 7. Thanks very much indeed
Don UK - Responder
I notice these instructions don't require removing HD & memory, which would seem to confirm it's not necessary to do so for a Toshiba Satelite L300, which is virtually the same as a C660 apart from not having a separate number pad.
Incidentally these instructions can also be for replacing a C650 keyboard as I have just done so successfuly thanks for the very clear instructions, so full marks!
John Smith - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 48
Duração total: 11,515
