Ir para o conteúdo principal
Toshiba Satellite C660 Keyboard Replacement
O que você precisa
Vídeo de Apresentação
  1. Toshiba Satellite C660 Keyboard Replacement, Keyboard replacement: passo 1, imagem 1 %32 Toshiba Satellite C660 Keyboard Replacement, Keyboard replacement: passo 1, imagem 2 %32
    • Remove the charger and the battery.
  2. Toshiba Satellite C660 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite C660 Keyboard Replacement: passo 2, imagem 2 %32 Toshiba Satellite C660 Keyboard Replacement: passo 2, imagem 3 %32
    • After removing the narrow plastic lid, you will see 4x Phillips screw.
  3. Toshiba Satellite C660 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite C660 Keyboard Replacement: passo 3, imagem 2 %32 Toshiba Satellite C660 Keyboard Replacement: passo 3, imagem 3 %32
    • Pick up the keyboard and disconnect the flex cable.
  4. Toshiba Satellite C660 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite C660 Keyboard Replacement: passo 4, imagem 2 %32 Toshiba Satellite C660 Keyboard Replacement: passo 4, imagem 3 %32
    • Now connect the new Keyboard. It was very easy. :-)
Conclusão
12 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
194.147 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
326 Membros
Autoria de 1.672 guias
5Comentários do guia
Hi there, Thank you very much.. please help me .. i broke that white plastic draw beneath the keyboard cable while was pushing it away to take the cable off .. what to do please?
Reef - Responder
You can put a piece of plaster tape to attach the tablecloth with the plug. Take a piece of chatertone (electric tape) to avoid short circuiting.
Hyperion - Responder
Abdelhamid Fathy Amer - Responder
Great stuff, I actually fixed my ancient and loved laptop, why is it loved? I hate Win 10 and have a new ASUS which is ace and super fast, but it is still Win 10 that I cannot get to grips with, but cannot restore the ASUS with Win 7. Thanks very much indeed
Don UK - Responder
I notice these instructions don't require removing HD & memory, which would seem to confirm it's not necessary to do so for a Toshiba Satelite L300, which is virtually the same as a C660 apart from not having a separate number pad.
Incidentally these instructions can also be for replacing a C650 keyboard as I have just done so successfuly thanks for the very clear instructions, so full marks!
John Smith - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 64
Ao todo: 11,545
