Toshiba Satellite C55D-B5206 Speakers Replacement
Introdução
Ir para o passo 1This guide will show you how to remove the speakers from a Toshiba Satellite C55D-B5206 laptop. This process is relatively simple, but it has a lot of steps and will require some time.
O que você precisa
Ferramentas
Exibir mais…
Turn the laptop upside down so the battery faces upwards.
Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
Remove the three 7 mm Philips head screws by turning the screws counter clockwise.
Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
Remove all pieces of yellow polyimide tape that covers the connectors and cables on the motherboard.
With the motherboard removed, both speakers are now easily available to remove.
