Ir para o conteúdo principal
Toshiba Satellite C55D-B5206 RAM Replacement
David Amodei
David Amodei e 4 outros colaboradores
Última atualização em January 25, 2024
15 - 30 minutos
Moderada
Pontos lista!
Melhor Introdução
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Toshiba Satellite C55D-B5206 RAM Replacement, RAM: passo 1, imagem 1 %32
    • First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • Make sure to put your screws in a safe place to make sure they do not get lost.
  2. Toshiba Satellite C55D-B5206 RAM Replacement: passo 2, imagem 1 %32
    • Once you take the screws out, take the battery off; it should slide off easily.
  3. Toshiba Satellite C55D-B5206 RAM Replacement: passo 3, imagem 1 %32
    • Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
  4. Toshiba Satellite C55D-B5206 RAM Replacement: passo 4, imagem 1 %32
    • Then, carefully take off the back casing of the laptop and set it aside.
  5. Toshiba Satellite C55D-B5206 RAM Replacement: passo 5, imagem 1 %32
    • This is where the RAM is located that you will be replacing.
  6. Toshiba Satellite C55D-B5206 RAM Replacement: passo 6, imagem 1 %32
    • There are two clips holding the RAM in place.
    • You will need to hold both of them back to be able to safely remove the RAM.
    • Use plastic spudgers, as the metal spudgers pictured here are not ESD-safe.
  7. Toshiba Satellite C55D-B5206 RAM Replacement: passo 7, imagem 1 %32
    • Gently remove the RAM and insert replacement.
Conclusão
Um comentário
This guide was done wonderfully. My critique for your group is to be more specific with the direction of how to pull/place the components of the device. Your instructions were simple, yet clear. Great work.
Dan Hartzell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 575
