Ir para o conteúdo principal
Toshiba Satellite C55D-A5108 Back Cover Replacement
Kristen Gismondi
Kristen Gismondi e 2 outros colaboradores
Última atualização em June 7, 2024
20 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to remove and replace the back cover of your Toshiba Satellite C55D-A5108. The back cover provides security to the inner components of your laptop, while also providing grip and helping prevent overheating.
This guide will remove the back cover of your laptop, the battery, and hard drive. You will also be putting the components back together. If you do not feel confident with doing this yourself, please find someone that can help you with the process.
O que você precisa
Ferramentas
  1. Toshiba Satellite C55D-A5108 Back Cover Replacement, Battery: passo 1, imagem 1 %32
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Back Cover Replacement: passo 2, imagem 1 %32
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Back Cover Replacement: passo 3, imagem 1 %32
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Back Cover Replacement, Hard Drive: passo 4, imagem 1 %32
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Back Cover Replacement: passo 5, imagem 1 %32
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: passo 6, imagem 1 %32 Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: passo 6, imagem 2 %32 Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: passo 6, imagem 3 %32
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
Conclusão
Uma outra pessoa concluiu este guia.
Kristen Gismondi
Membro desde: 11/12/14
92.429 Reputação
Autoria de 241 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.540 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Ao todo: 271
