Ir para o conteúdo principal
Toshiba Satellite C55-C5240 Motherboard Replacement
Abdel Feliciano Gonzalez
Abdel Feliciano Gonzalez e 2 outros colaboradores
Última atualização em November 18, 2023
10 - 20 minutos
Moderado
Guia do aluno destaque
Introdução
Ir para o passo 1
The motherboard is a large and central part to the laptop. Most components either connect or interface with it in some manner. Because there is a lot involved, this guide will show how to remove it properly.
O que você precisa
Ferramentas
  1. Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 2, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 2, imagem 3 %32
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: passo 3, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: passo 3, imagem 2 %32
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 4, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 4, imagem 3 %32
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: passo 5, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: passo 5, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: passo 5, imagem 3 %32
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 6, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 6, imagem 3 %32
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 7, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 7, imagem 3 %32
    • Peel off the rubber hard drive mount.
  8. Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: passo 8, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: passo 8, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: passo 8, imagem 3 %32
    • Slide the disk drive to the right and gently lift up the disk out the laptop.
  9. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 9, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 9, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 9, imagem 3 %32
    • Disconnect the 5 ribbon cables.
    • To remove, unlock the latch of each ribbon and pull it out.
  10. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 10, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 10, imagem 2 %32
    • There is a wifi card underneath the large ribbon cable on the right.
    • Remove the plastic piece that covers the screw.
  11. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 11, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 11, imagem 2 %32
    • Unscrew the PH1 Phillips head 3.0 mm long screw holding it in.
    • Pull out the WiFi card.
  12. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 12, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 12, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 12, imagem 3 %32
    • Disconnect the 4 regular cables.
    • Carefully pull the cable parallel to the board, not up or at an angle.
  13. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 13, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 13, imagem 2 %32
    • Unscrew the seven PH1 Phillips head 3.0 mm long screws that hold the motherboard in place.
  14. Toshiba Satellite C55-C5240 Motherboard Replacement: passo 14, imagem 1 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 14, imagem 2 %32 Toshiba Satellite C55-C5240 Motherboard Replacement: passo 14, imagem 3 %32
    • Carefully lift the motherboard from the edges.
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S1-G5, Nance Spring 2017 Membro de USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Membros
Autoria de 18 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 42
Ao todo: 7,505
