Ir para o conteúdo principal
Toshiba Satellite C55-C5240  RAM Replacement
Angela Rodriguez
Angela Rodriguez e 2 outros colaboradores
Última atualização em November 12, 2023
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
This is a guide that will assist you with replacing your RAM in a Toshiba Satellite C55-C5240.
O que você precisa
Ferramentas
  1. Toshiba Satellite C55-C5240  RAM Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-C5240  RAM Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-C5240  RAM Replacement, Battery: passo 1, imagem 3 %32
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240  RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-C5240  RAM Replacement: passo 2, imagem 2 %32 Toshiba Satellite C55-C5240  RAM Replacement: passo 2, imagem 3 %32
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240  RAM Replacement, Back cover: passo 3, imagem 1 %32 Toshiba Satellite C55-C5240  RAM Replacement, Back cover: passo 3, imagem 2 %32
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240  RAM Replacement: passo 4, imagem 1 %32 Toshiba Satellite C55-C5240  RAM Replacement: passo 4, imagem 2 %32 Toshiba Satellite C55-C5240  RAM Replacement: passo 4, imagem 3 %32
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240  RAM Replacement, RAM: passo 5, imagem 1 %32 Toshiba Satellite C55-C5240  RAM Replacement, RAM: passo 5, imagem 2 %32 Toshiba Satellite C55-C5240  RAM Replacement, RAM: passo 5, imagem 3 %32
    • The RAM is at the upper middle area of the motherboard.
    • Push down on the clips on either side of the RAM stick evenly.
    • It will come loose in an angle once the clips are released.
  6. Toshiba Satellite C55-C5240  RAM Replacement: passo 6, imagem 1 %32
    • Simply pull out the RAM stick.
    • These steps work for both sticks of RAM.
Conclusão
Angela Rodriguez
Membro desde: 02/28/17
261 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G5, Nance Spring 2017 Membro de USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Membros
Autoria de 18 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 1,595
