Toshiba Satellite C55-A5300 Battery Replacement
Introdução
Ir para o passo 1This guide will help you if you need to replace the battery in your laptop. Replacing the battery will fix any issues caused by a old or faulty battery. It is very straightforward and can be completed regardless of technical knowledge or skill level.
O que você precisa
Ferramentas
With the Laptop off, turn it over.
The battery is located next to the screen hinges.
Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
Uma outra pessoa concluiu este guia.
