Ir para o conteúdo principal
Toshiba Satellite A215 S4697 Hard Drive Replacement
Mike Dongyub Ryu
Mike Dongyub Ryu e 8 outros colaboradores
Última atualização em September 30, 2024
5 - 10 minutos
Fácil
Guia do aluno destaque
Replacing a hard drive is a great yet simple fix. Make sure your new drive is the 2.5" laptop hard drive!
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Toshiba Satellite A215 S4697 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 2, imagem 2 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 2, imagem 3 %32
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
  3. Toshiba Satellite A215 S4697 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Locate the hard drive in the left hand corner, and remove the two 4mm Phillips #1 screws.
  4. Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 4, imagem 2 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, open the compartment and remove the compartment cover.
  5. Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of metal tweezers to grab the plastic pull-tab that is tucked in underneath the hard drive.
  6. Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 6, imagem 2 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 6, imagem 3 %32
    • Using the plastic pull-tab, carefully pull the hard drive to the left to detach it from its connector.
    • Remove the hard drive assembly from the device.
    • This assembly consists of the actual hard drive and the metal housing. Metal housing is necessary for the reassembly of the device.
  7. Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 7, imagem 2 %32
    • Flip over the hard drive assembly and remove two 4mm Phillips #1 screws at the top left and right side of the hard drive housing.
  8. Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 8, imagem 1 %32 Toshiba Satellite A215 S4697 Hard Drive Replacement: passo 8, imagem 2 %32
    • Carefully separate the actual hard drive from the hard drive assembly.
    • Do not touch the hard drive's connectors.
Conclusão
14 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 4-12, Maness Spring 2013 Membro de Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
Membros da 4
Autoria de 18 guias
2 comentários
What if I don't have the metal housing
Joshua Helms - Responder
I bought the laptop from someone and it didn't have the metal housing and the laptop just keeps going from startup screen to loading back and fourth can someone help
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 39
Duração total: 33,252
