Toshiba Satellite A105-S4011 Battery Replacement
Introdução
Ir para o passo 1This guide will help you take out the battery, and replace it with a new one. Changing the battery is easy and simple.
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
6 outras pessoas executaram este guia.
2 comentários
I have Toshiba E45t-A4300 soft touch screen. The battery is spoilt. The battery compartment is not accessible. How do I remove it and replace it with a new one,?
The part number is PSUB2U-00K00P
