Toshiba Portege R700-S1312 Fan Replacement
O que você precisa
Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
Begin by removing 14 70mm screws from the back cover of the laptop using a Phillips #00 Screwdriver. Do not attempt to remove the back cover just yet though.
