Ir para o conteúdo principal
Toshiba Portege R205-S209 Heatsink Fan Replacement
Jason Sizen
Jason Sizen e um outro colaborador
Última atualização em April 8, 2023
5 - 10 minutos
Moderada
Precisa de melhores imagens
Faltando detalhes
Replacing the heatsink fan is an uncommon issue however if you laptop is running extremely hot this may be the correct adjustment. Removing the heatsink may seem intimidating, but it is relatively quick taking only about 5-10 minutes to complete.
O que você precisa
Ferramentas
  1. Toshiba Portege R205-S209 Heatsink Fan Replacement, Heatsink Fan: passo 1, imagem 1 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement, Heatsink Fan: passo 1, imagem 2 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement, Heatsink Fan: passo 1, imagem 3 %32
    • With the laptop flipped over, unlock the mechanism that is shown in red.
    • Lift and remove the battery out of the device.
  2. Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 2, imagem 1 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 2, imagem 2 %32
    • Remove the accessory plate by unscrewing the single Phillips #0 screw and lifting up the panel.
  3. Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 3, imagem 1 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 3, imagem 2 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 3, imagem 3 %32
    • Remove the 18 Phillips #0 screws that keep the bottom plate attached to the outer portion of the laptop.
  4. Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 4, imagem 1 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 4, imagem 2 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 4, imagem 3 %32
    • Remove the 2 Phillips #0 screws holding the heat sink in place.
    • Detach the heatsink fan from the motherboard by removing the clip that connects them together and pulling away from the laptop horizontally.
Conclusão
Jason Sizen
Membro desde: 04/04/19
193 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G2, Crossman Spring 2019 Membro de IUPUI, Team S1-G2, Crossman Spring 2019
IUPUI-CROSSMAN-S19S1G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 190
