Toshiba Portege R205-S209 Battery Replacement
Introdução
Ir para o passo 1You may need to replace your laptop's battery if it is not holding a charge anymore, or not charging at all. To replace the battery on the Toshiba Portege laptop, no tools are necessary, just your own fingers!
Flip the laptop over. Keep the front end facing away from you, so the battery appears at the top.
Uma outra pessoa concluiu este guia.
