Toshiba Portege M400 Battery Replacement
Introdução
Ir para o passo 1In this guide, you will learn how to replace a battery that doesn't charge properly or anymore. This guide will also teach you what the proper and necessary tools are for this repair.
Make sure the battery lock switch is in the unlocked position.
Slide the battery release towards the arrow to disengage the battery.
Uma outra pessoa concluiu este guia.
