Ir para o conteúdo principal
Toshiba L15W-B1303 Battery Replacement
Peyton Campbell
Peyton Campbell e um outro colaborador
Última atualização em January 18, 2023
5 minutos
Fácil
Introdução
Ir para o passo 1
Use this guide to replace the battery in your Toshiba Satellite L15W-B1303.
The battery is a very important component of your laptop and is its main source of power. A battery that doesn’t work properly will result in your laptop not turning on or shutting off at random times. This is very dangerous because you can lose important work and files on your laptop depending on when the laptop decides to shut off.
Before deciding to replace your battery, check out the troubleshooting guide first. On many occasions, the battery in your laptop can work properly again with a new charging adapter and/or cable.
If you have a swollen battery, follow this guide here. A swollen battery can be potentially dangerous and cause a fire or explode; remove it yourself with extreme caution.
Be sure to turn your laptop off before starting the replacement process.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Toshiba L15W-B1303 Battery Replacement, Bottom Panel: passo 1, imagem 1 %32 Toshiba L15W-B1303 Battery Replacement, Bottom Panel: passo 1, imagem 2 %32 Toshiba L15W-B1303 Battery Replacement, Bottom Panel: passo 1, imagem 3 %32
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba L15W-B1303 Battery Replacement, Battery: passo 2, imagem 1 %32 Toshiba L15W-B1303 Battery Replacement, Battery: passo 2, imagem 2 %32 Toshiba L15W-B1303 Battery Replacement, Battery: passo 2, imagem 3 %32
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
Conclusão
Peyton Campbell
Membro desde: 01/22/20
145 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 496
