Ir para o conteúdo principal
Toshiba Equium M70 Faulty Graphics
Terry Sim
Terry Sim e 4 outros colaboradores
Última atualização em May 19, 2020
2 horas
Moderada
Texto confuso
Pré-requisitos ausentes
Guia colaborativo
The fix, I place a thin alloy shim between the existing heatsink & chip, with a good quality thermal paste, I always use artic silver 5(never lets you down)
O que você precisa
Ferramentas
  1. Toshiba Equium M70 Faulty Graphics, Toshiba Equium M70 Faulty Graphics: passo 1, imagem 1 %32
    • This is a complete top half strip down to fix (takes me less than 30 minutes)
  2. Toshiba Equium M70 Faulty Graphics: passo 2, imagem 1 %32
    • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
  3. Toshiba Equium M70 Faulty Graphics: passo 3, imagem 1 %32
    • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
  4. Toshiba Equium M70 Faulty Graphics: passo 4, imagem 1 %32
    • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
  5. Toshiba Equium M70 Faulty Graphics: passo 5, imagem 1 %32
    • THen apply more thermal paste to the top of the shim
  6. Toshiba Equium M70 Faulty Graphics: passo 6, imagem 1 %32
    • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
  7. Toshiba Equium M70 Faulty Graphics: passo 7, imagem 1 %32
    • This is the CPU with the new alloy shim fitted.
Conclusão
3 outras pessoas executaram este guia.
Terry Sim
Membro desde: 02/12/11
207 Reputação
Autoria de 1 guia
Um comentário
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 2,087
