Toshiba Dynabook AX 53D Hard Drive Replacement
Introdução
Ir para o passo 1In this guide users will be walked through the process of removing both of the hard drives located in the Toshiba Dynabook AX 53D. This includes removing the drive cover panels, pulling out the drive, and removing the drive from its metal retaining plate.
O que você precisa
Start by using the #J1 screw bit to unscrew the the two 4.6 mm hard drive bay screws located on the underside of the laptop. They are located next to the Windows license sticker.
