Ir para o conteúdo principal
Toilet Flapper Replacement
Kristen Gismondi
Kristen Gismondi e um outro colaborador
Última atualização em July 2, 2020
5 - 10 minutos
Fácil
Introdução
Ir para o passo 1
The toilet flapper opens to allow water to flow from the toilet tank into the bowl when the toilet is flushed. Afterwards, it closes as the toilet tank fills back up. If water is constantly flowing from your toilet tank, chances are your flapper is not functioning properly and will require a replacement.
  1. Toilet Flapper Replacement, Tank Lid: passo 1, imagem 1 %32 Toilet Flapper Replacement, Tank Lid: passo 1, imagem 2 %32 Toilet Flapper Replacement, Tank Lid: passo 1, imagem 3 %32
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: passo 2, imagem 1 %32 Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: passo 2, imagem 2 %32
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Flapper Replacement, Draining a Toilet Tank: passo 3, imagem 1 %32 Toilet Flapper Replacement, Draining a Toilet Tank: passo 3, imagem 2 %32
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: passo 4, imagem 1 %32 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: passo 4, imagem 2 %32 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: passo 4, imagem 3 %32
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  5. Toilet Flapper Replacement, Flapper: passo 5, imagem 1 %32 Toilet Flapper Replacement, Flapper: passo 5, imagem 2 %32 Toilet Flapper Replacement, Flapper: passo 5, imagem 3 %32
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
Conclusão
6 outras pessoas executaram este guia.
Kristen Gismondi
Membro desde: 11/12/14
92.993 Reputação
Autoria de 241 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.807 guias
2Comentários do guia
Thank you I needed that
My Mama - Responder
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - Responder
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 41
Últimos 30 dias: 183
Ao todo: 14,806
