Testing Power Cord Continuity
Introdução
Ir para o passo 1A detailed guide on how to use a continuity tester to check for adequate electrical connection on a power cord.
O que você precisa
Set the multimeter to continuity test mode.
Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
Test for a potential open circuit by using one multimeter lead to touch one of the prongs on the AC side of power cord. Use the other lead to touch one end of the console side of the power cord.
Repeat the above directions in step 2 for the other outlet and prong of the power cord.
Est-il possible de brancher sur une autre prise alimentée pour savoir si cordon et appareil sont non défectueux ??? Sans danger; faire sauter fusibles etc. Merci.
Could that be the problem why I am not getting but just a tad of electricity to my outlets I'm not getting enough power to run anything?
Test for a potential short circuit by touching each prong on the AC side of the power cord.
If your power cord has passed all of the steps above, then you have successfully tested that your power cord is in working order.
is there a guide like this very useful one but to test the surface power cords ?
Genial,,la mejor explicación q encontré. Muchas gracias
152 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all15Comentários do guia
Thank you very much.
Wow Wow Just a Great Guide, Now I have learned one more skill :)
Brilliant love it
Superb...thanks a lot!!
Now I know how to test a power cord.
How do I test a switch?
Can you do a continuity test on the Xbox One Original CONSOLE ?
How can I test a cable if one end is in the basement and the other end is on the second floor?
To test a cable with ends in different locations, you can use a continuity tester with a remote. These testers include a main unit and a remote probe that connects to one end of the cable. Place the remote device on one end (e.g., the basement) and use the main unit on the other end (e.g., the second floor). The tester will indicate continuity if the cable is intact, making it easy to test cables over long distances without additional wires or helpers.
