Ir para o conteúdo principal
Testing Power Cord Continuity
Darren Chan
Darren Chan e 10 outros colaboradores
Última atualização em 11 de mar de 2025
1 - 5 minutos
Muito fácil
Introdução
Ir para o passo 1
A detailed guide on how to use a continuity tester to check for adequate electrical connection on a power cord.
O que você precisa
  1. Testing Power Cord Continuity, Set the multimeter to continuity test mode: passo 1, imagem 1 %32 Testing Power Cord Continuity, Set the multimeter to continuity test mode: passo 1, imagem 2 %32
    • Unplug the power cord from the device and from the AC outlet. Failure to do so can result in electrical shock or death.
    • Set the multimeter to continuity test mode.
    • The setting is symbolized by a diode or sound wave symbol as seen in the pictures. If the meter is set to the correct mode, you should hear the meter beep when the leads are touched together.
    • Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
  2. Testing Power Cord Continuity, Test for a break in the cable: passo 2, imagem 1 %32
    • Test for a potential open circuit by using one multimeter lead to touch one of the prongs on the AC side of power cord. Use the other lead to touch one end of the console side of the power cord.
    • If there is an adequate electrical connection, the multimeter will continuously beep. A short beep does not mean that there is continuity. If it does not beep the first time, try using the lead to touch the other prong.
    • Repeat the above directions in step 2 for the other outlet and prong of the power cord.
    • If the multimeter fails to beep on any of the occasions outlined above, your power cord is open. In other words, you will need to replace the power cable.
  3. Testing Power Cord Continuity, Test for a short: passo 3, imagem 1 %32
    • Once you have verified that the power cord provides an adequate electrical connection, you will have to test that the cable is not shorted.
    • Test for a potential short circuit by touching each prong on the AC side of the power cord.
    • If the multimeter beeps, your power cord is bad and must be replaced immediately.
    • If your power cord is shorted, do not attempt to replug the cord into the AC outlet.
    • If your power cord has passed all of the steps above, then you have successfully tested that your power cord is in working order.
Linha de Chegada
152 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Darren Chan
Membro desde: 10/28/09
5.371 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 5-1, Regan Fall 2009 Membro de Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Membros
Autoria de 21 guias
2Comentários do guia
Great Article,you can use a little bubble to let electric current light the bubble,make sure use the correct voltage of ,Example ,if you are in Europe,then you need to use 220V Europe power cord http://www.yunhuanelectric.com/Europe-po... to test.
huaiancg - Responder
An electrician respond your call within an hour in dubai . so they have guideline to do electrical work with safety. <a href="https://handyman-dubai.com/electrician-d...>electrician in dubai</a> they have tools of testing power all time with them . they resolve issue with that.
rene moris - Responder
Comentar
Visualizações:
Últimas 24 horas: 54
Últimos 7 dias: 458
Últimos 30 dias: 1,692
Ao todo: 266,999
