Ir para o conteúdo principal
Teenage Engineering OP-1 Connector Board Replacement
teenage engineering
teenage engineering e 2 outros colaboradores
Última atualização em December 4, 2024
10 minutos
Fácil
Use this guide to replace the Connector Board of the OP-1, including the microphone, the line-in / line-out connectors and the USB port.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: passo 1, imagem 1 %32 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: passo 1, imagem 2 %32 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: passo 1, imagem 3 %32
    • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
    • Lift the back panel and remove it. The Connector Board is revealed.
  2. Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: passo 2, imagem 1 %32 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: passo 2, imagem 2 %32 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: passo 2, imagem 3 %32
    • Disconnect the flex connector by lifting it up with a spudger.
    • Remove the three Phillips screws. Do not lose the washer at the bottom screw.
    • Take out the connector board.
    • Make sure to keep the black rubber pad underneath the board.
  3. Teenage Engineering OP-1 Connector Board Replacement: passo 3, imagem 1 %32 Teenage Engineering OP-1 Connector Board Replacement: passo 3, imagem 2 %32
    • Don't forget the cover for the on/off switch.
    • Simply take it off from the old board and transfer it to the new board.
Conclusão
46 outras pessoas executaram este guia.
teenage engineering
Membro desde: 10/23/13
1.095 Reputação
Autoria de 2 guias
Equipe
Teenage Engineering Membro de Teenage Engineering
Community
Membros da 3
Autoria de 7 guias
44 comentários
Veeery useful , thank you !
mouchtouris alexandre - Responder
Even with the Jimmy I can't seem to get the back panel off... a video would be helpful :)
Shawn Ivie - Responder
Got the back panel off finally but my connector board won't come out.
Ok... finally got the connector board out. It took a bit of gentle prying using a very small thin screw driver bit on each side of the connector board. Once I had the right side popped up a bit I was able to push on the input output jacks from the outside to get clearance. Removing the connector board and putting it back in resolved the power switch issues I was experiencing. No new connector board needed! :)
Im so glad I was reading these comments. I had an OP1 with failing power as well, every bit more tougher touch would turn it off and on, or sometimes would have problems starting up.
I took it apart to see if something was bothering, and taking off the white power switch actually solved it haha.
Good I didnt order it yet!
J-J -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 70
Últimos 30 dias: 225
Duração total: 49,144
