Ir para o conteúdo principal
TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement
masato tsuchida
masato tsuchida e 2 outros colaboradores
Última atualização em January 8, 2023
5 minutos
Fácil
This guide will walk you through the necessary steps for replacing the power jack on your Toshiba Satelite E45W-C4200X.
The power jack has been a common problem with the Toshiba Satellite laptops and the replacement is quick and relatively inexpensive.
Before using this guide, make sure to review the troubleshooting page to ensure this replacement is necessary.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: passo 1, imagem 1 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: passo 1, imagem 2 %32
    • Remove the ten 1 mm screws that secure the back cover using a Phillip's #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 2, imagem 1 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 2, imagem 2 %32
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommended that you start from a corner and run the tool along the edge
  3. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 3, imagem 1 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 3, imagem 2 %32
    • Using a Phillips # 1 screwdriver, remove the three screws holding the bracket over the ports on the right side.
    • Remove the bracket.
  4. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 4, imagem 1 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 4, imagem 2 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 4, imagem 3 %32
    • Unplug the power cable harness from the motherboard.
    • Lift the power jack out of its slot in the top right corner.
    • Remove the cable.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Thanks for this. Great help in sorting out my laptop.
Jack - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 647
