Ir para o conteúdo principal
TOSHIBA Satellite E45W-C4200X Battery Replacement
John Tangney
John Tangney e 3 outros colaboradores
Última atualização em January 8, 2023
15 minutos
Fácil
Introdução
Ir para o passo 1
This guide will walk you through the necessary steps for replacing the battery pack in your Toshiba Satelite E45W-C4200X.
The battery is a vital piece of hardware that allows the laptop to run when not plugged in. A defective battery can prevent the laptop from turning and can result in longer charging times or short battery life.
Before using this guide, make sure to review the troubleshooting page oftentimes, the battery can be fixed without replacing it.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: passo 1, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X Battery Replacement: passo 2, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Battery Replacement: passo 2, imagem 2 %32
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X Battery Replacement: passo 3, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Battery Replacement: passo 3, imagem 2 %32
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X Battery Replacement: passo 4, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Battery Replacement: passo 4, imagem 2 %32
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Battery Replacement: passo 5, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Battery Replacement: passo 5, imagem 2 %32
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X Battery Replacement: passo 6, imagem 1 %32
    • Remove the battery from the laptop.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
My laptop is only working while plugged in i recently changed the battery and the problem persist. Any idea what else it can be ?
Gabriel Meza - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 2,319
