Ir para o conteúdo principal
T-Mobile Sparq Battery Replacement
LeAnn Lewis
LeAnn Lewis e um outro colaborador
Última atualização em June 25, 2018
2 minutos
Fácil
Introdução
Ir para o passo 1
This guide will show you how to replace the battery in your T-Mobile Sparq or (Alcatel 606a). This is a fairly straight forward procedure that involves removing the back cover of the phone, removing the old battery and installing a new one.
O que você precisa
Peças
Ferramentas
  • Spudger
    Spudger
  1. T-Mobile Sparq Battery Replacement, Battery: passo 1, imagem 1 %32
    • If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
    • Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
  2. T-Mobile Sparq Battery Replacement: passo 2, imagem 1 %32
    • Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
    • Insert the tip of your finger into the groove and gently lift the battery from the case.
Conclusão
Uma outra pessoa concluiu este guia.
LeAnn Lewis
Membro desde: 04/07/18
539 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team S3-G3, Wilson Spring 2018 Membro de IUPUI, Team S3-G3, Wilson Spring 2018
IUPUI-WILSON-S18S3G3
3 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 242
