Ir para o conteúdo principal
Subwoofer Rubber Surround Repair
Miroslav Djuric
Miroslav Djuric e um outro colaborador
Última atualização em September 28, 2024
30 minutos
Moderado
Introdução
Ir para o passo 1
I realized — a little too late — that a couple of retaining clips were rubbing against the top of the subwoofer/enclosure in my car. One clip was (thankfully) scratching the subwoofer enclosure carpet, but the other one had poked a hole on the subwoofer's rubber surround.
I removed the retaining clips so there would be no issues in the future, but the damage had already been done. So I figured what the heck — might as well make a guide!
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Subwoofer Rubber Surround Repair, Subwoofer Rubber Surround Repair: passo 1, imagem 1 %32 Subwoofer Rubber Surround Repair, Subwoofer Rubber Surround Repair: passo 1, imagem 2 %32
    • Assess the damage. Depending on the severity of the cut, you may need some other scaffolding material (aside from RTV silicone) to enclose the hole.
    • This is especially true if a chunk of the rubber material is completely missing from the rubber surround.
    • In this case, all we need to do is cover up the tear with RTV silicone in order to make the subwoofer almost as good as new — functionally, at least.
  2. Subwoofer Rubber Surround Repair: passo 2, imagem 1 %32 Subwoofer Rubber Surround Repair: passo 2, imagem 2 %32 Subwoofer Rubber Surround Repair: passo 2, imagem 3 %32
    • Unscrew the eight #2 Phillips screws using either a screwdriver or cordless driver.
    • Be careful if you use a cordless driver for either screwing or unscrewing — you don't want to strip the screws or the enclosure's holes. You also don't want to accidentally create another hole in the rubber surround with either tool.
  3. Subwoofer Rubber Surround Repair: passo 3, imagem 1 %32 Subwoofer Rubber Surround Repair: passo 3, imagem 2 %32
    • Use a flat pry tool (such as a flat-blade screwdriver) to prop up an edge of the subwoofer.
    • In my case, I just used the Phillips #2 screwdriver I had on-hand.
    • Slide your fingers underneath the sub so that you get a good grip on its edge.
    • Carefully lift the subwoofer out of the enclosure, minding any wires that may be tethering the sub to the enclosure.
  4. Subwoofer Rubber Surround Repair: passo 4, imagem 1 %32 Subwoofer Rubber Surround Repair: passo 4, imagem 2 %32
    • Use a clean, lint-free cloth to wipe away any dirt/grease/grime that would otherwise tarnish the bond between the rubber and RTV silicone.
    • Inspect the underside of the tear and also gently clean it with a cloth, if needed.
    How do you repair the whole thing?
    MARCOS ORTEGA - Responder
  5. Subwoofer Rubber Surround Repair: passo 5, imagem 1 %32 Subwoofer Rubber Surround Repair: passo 5, imagem 2 %32 Subwoofer Rubber Surround Repair: passo 5, imagem 3 %32
    • Time to get dirty. Put on your favorite brand of nitrile or latex gloves.
    • Put a dab of RTV silicone on a disposable plate, or some other clean, non-essential surface.
  6. Subwoofer Rubber Surround Repair: passo 6, imagem 1 %32 Subwoofer Rubber Surround Repair: passo 6, imagem 2 %32 Subwoofer Rubber Surround Repair: passo 6, imagem 3 %32
    • Cut the end off a cotton swab in order to transform it into an RTV applicator.
    • Alternatively you can try removing all of the cotton from the swab, but you certainly do not want any cotton fibers to remain on the swab.
    • Dip the swab into the RTV silicone, and use it to apply the RTV silicone to the underside of the subwoofer tear.
    • You do not need a huge amount of RTV silicone on either side of the rubber surround — just enough to form a very thin layer.
  7. Subwoofer Rubber Surround Repair: passo 7, imagem 1 %32 Subwoofer Rubber Surround Repair: passo 7, imagem 2 %32 Subwoofer Rubber Surround Repair: passo 7, imagem 3 %32
    • With the underside coated, put a dab of RTV silicone onto your gloved finger.
    • Gently spread the RTV silicone across the front of the torn subwoofer surround.
    • Again, you don't need gobs of RTV silicone in order to make a strong bond — just enough to form a thin layer.
    • Perform this action at your own risk -- you may inadvertently open up the hole again, depending on its size.
    • Push down a couple of times on the center of the subwoofer to ensure that the RTV silicone doesn't accidentally impede the movement of the sub.
  8. Subwoofer Rubber Surround Repair, Optional Step: passo 9, imagem 1 %32
    • After you're done applying the RTV silicone and testing the subwoofer's excursion, shine a strong flashlight through the now-covered hole, and ensure that no light bleeds through.
    • Ensure the sub wires are still connected properly, and reinstall the subwoofer back into the enclosure.
    R42 irderezirderezddS3Q
    trent hewitt - Responder
    Is there anyway to replace the.entire rubber surround.
    Darold Ellsworth - Responder
Linha de Chegada
25 outras pessoas executaram este guia.
19Comentários do guia
Did this method really work? Did u test your subs? Does the kind of silicone matter clear or black? I read forums and a product u can purchase at walmart called Shoe Goo would be the perfect candidate its flexible sealant.
Makkara - Responder
Also I have a Kicker L5 12" that has a small rip like a 1/4".
Makkara - Responder
I have repaired many using fingernail polish. It may take several applications depending on the size but it forms a strong durable bond. Also works great on the cone.
Matthew Putman - Responder
Where would I find this EVE silicone?
adamh2582 - Responder
Just be careful what silicone you use. Some may degrade the cone and other parts of the subwoofer.
Andrew Powers - Responder
what should be used on sundown sa12
tlkool1974 -
how to repair nakamichi nbf100a subwoofer power side,please give me the circute diagram
anu.ad58 - Responder
what brand should e used on sundown sa12
tlkool1974 - Responder
Can I use any Rubber repair kit to replace my damaged rubber on my kicker 10”?
cd70451
cd70451 - Responder
Thanks for sharing wounderull information, With the example for pix.
ROCKFORD FOSGATE PUNCH P3 shallow mount subwoofer
Sara - Responder
LAUGH all you want but I came up with a super fast, and long lasting fix for speaker surround tears/holes.. without having to remove the speaker from the enclosure ( home or car)—- DRYER SHEETS.. these things not only help debug your windshield and grill but are also great in AC vets for that fresher smell— but I digress—- use just a tiny baby bandaid size strip with some speaker glue instant gasket or (Simply Speakers MI-3035) and you have created a long last flexible bainaide for the speaker with minimal effort cost and down time!
Bob - Responder
I
I have a question
Ashlee - Responder
Here is a step by step process to Subwoofer Rubber Surround Repair technique, Thanks for sharing this post. https://bestcarmusic.blogspot.com/2018/1...
kristen brown - Responder
My tear was 1/4” in a Boston G1. I used a little “Tear Mender” and made sure I got it in the tear. Used a sharpie to color it.
RadioShack - Responder
I used 100% RTV silicone and wax paper to hold the tear together. Worked perfectly! Thanks for the post.
Haroon Yusuf - Responder
Is there a kit for the part in the middle of cone its like been hit with hammer but i wanto see if its fix able its a kicker comp 15 inch sub i have 2 and 3 12 inch of same .just woundering if theres any hope thanks.
Mariezee Méndez - Responder
If i use multimeter to make sure speaker is all the way bliwn i put it on oms ,after that it goes .43 .48 is that good or bad for my kicker 15 inch sub its been broken but yet if i plug it into stereo i here sound coming out still what is a goid and bad multimeter reading if u no anybody pls help thanku goidnite bless u all i love speakers music wat can i say if thered a way to save ut please let me no what to do
RTV silicone- (Room Temperature Vulcanization). Therefore, this silicone dries at room temperature.
See Aych - Responder
Next time, put a piece of plastic wrap over the top hole and fix the repair from the back once it’s dry pull the plastic off and away….when dry….use a dab and a razor blade to dress up the face smooth with the edge of blade.
Jaysen John Ivan Turner - Responder
Comentar
Visualizações:
Últimas 24 horas: 25
Últimos 7 dias: 118
Últimos 30 dias: 518
Ao todo: 132,193
