Esta tradução pode não refletir as atualizações mais recentes do guia de fontes. Ajude a atualizar a tradução ou veja guia de fontes.
Introdução
Se a tela do iPhone 13 Pro Max estiver rachada, não responder ao toque ou não mostrar nenhuma imagem quando o telefone estiver ligado, use este guia para restaurar o funcionamento do iPhone com uma nova tela, ou melhor, com um novo conjunto de tela.
Observação: A funcionalidade True Tone e brilho automático é desativada após a substituição da tela, mesmo quando se usa uma tela original da Apple. A identificação facial também é desativada, a menos que o iPhone esteja executando iOS 15.2 ou mais recente.
O que você precisa
Desligue o iPhone antes de iniciar a desmontagem.
Remova os dois parafusos pentalobe P2 de 6,8 mm que se encontram na borda inferior do iPhone.
Meça 3 mm a partir da ponta e marque a palheta com um marcador permanente.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
Coloque tiras sobrepostas de fita adesiva transparente sobre a tela do iPhone até que toda a superfície fique coberta.
Se não conseguir fazer com que a ventosa grude nas próximas etapas, dobre um pedaço de fita adesiva resistente (como fita adesiva vedante) na forma de uma pega e levante a tela com ela.
Puxe a pega azul para trás para destravar os braços do Anti-Clamp.
Deslize os braços pela borda esquerda do seu iPhone.
Posicione as ventosas próximo à borda inferior do iPhone - uma pela frente e a outra pela traseira.
Aperte as ventosas uma contra a outra para aplicar sucção na área desejada.
Com um secador de cabelos, aqueça a borda inferior do iPhone. A tela deve se sentir um pouco quente demais para ser tocada.
Aguarde um minuto para que o adesivo tenha a chance de se soltar e apresentar um vão.
Introduza uma palheta de abertura sob a moldura plástica da tela quando o Anti-Clamp criar um vão suficientemente grande.
Pule as próximas três etapas.
Com um secador de cabelos ou uma pistola de ar quente, aqueça a borda inferior do iPhone por 90 segundos ou até que a tela fique um pouco quente demais para ser tocada.
Aplique uma ventosa de sucção simples na borda inferior do telefone, evitando a borda do vidro.
Puxe a ventosa para cima com pressão firme e constante para criar um pequeno vão entre o painel dianteiro e estrutura traseira.
Introduza uma palheta de abertura no vão.
It took an outrageous amount of strength to get through the water tight seal, way more than the provided suction cup was able to do. The provided suction cup kept popping off of the screen, and when I finally was able to lift the screen enough to get a pick under, my screen immediately cracked
Com um secador de cabelos, aqueça a borda direita do iPhone (a borda com o botão liga/desliga) por 90 segundos ou até que a tela fique um pouco quente demais para ser tocada.
Passe a palheta ao redor do canto inferior direito do iPhone para cortar o seu adesivo.
Continue movendo para cima a ferramenta pela borda direita do iPhone até alcançar o canto direito superior.
Deixe a palheta no canto superior direito antes de continuar.
Com um secador de cabelos, aqueça a borda superior do iPhone por 90 segundos ou até que a tela fique um pouco quente demais para ser tocada.
Passe a palheta de abertura ao redor do canto superior direito do iPhone para separar o adesivo superior.
Deixe a palheta no canto superior esquerdo antes de continuar.
Com um secador de cabelos, aqueça a borda esquerda do iPhone por 90 segundos ou até que a tela fique um pouco quente demais para ser tocada.
Insira uma segunda palheta de abertura no canto inferior esquerdo do iPhone.
Faça movimentos giratórios de vai-e-vem com as duas palhetas simultaneamente, até que os clipes da borda esquerda se soltem.
Remova a sua ventosa de sucção da tela.
Abra o iPhone elevando o lado direito da tela e deixando o lado esquerdo embaixo, como se fosse virar a capa de um livro.
Apoie a tela em algo e deixe-a escorada enquanto executa trabalhos no telefone.
Ferramenta utilizada neste passo:Magnetic Project Mat$19.95
Com uma chave Y000, remova os três parafusos de 1,3 mm que prendem a capa do conector da bateria.
Com a ponta pontiaguda de uma espátula ou uma unha limpa, erga o conector da bateria de seu soquete na placa lógica.
Vire o conector ligeiramente para fora da placa lógica para evitar que ele entre acidentalmente em contato com o soquete e forneça energia ao telefone durante o reparo.
Com a ponta pontiaguda de uma espátula ou uma unha limpa, erga o conector da tela de seu soquete na placa lógica.
Com uma chave Y000, remova dois parafusos de 1,1 mm da capa do conector dos sensores frontais.
Com uma chave Phillips, remova os dois parafusos restantes da capa do conector dos sensores frontais:
Um parafuso de 1,5 mm
Um parafuso de 1,8 mm
Com uma chave Y000, remova os três parafusos de 1,4 mm que prendem o suporte do conjunto dos sensores.
Com uma pinça ou os seus dedos, remova o suporte do conjunto dos sensores frontais.
Aqueça um iOpener e aplique-o na borda superior da tela por dois minutos.
Insira uma palheta de abertura entre o sensor de luz ambiente e o seu recesso na tela.
Levante com a palheta para separar o sensor de luz ambiente da tela.
Insira uma palheta de abertura entre o sensor de proximidade e o seu recesso na tela.
Levante com a palheta para separar o sensor de proximidade da tela.
Com uma pinça ou os dedos, afaste o cabo do sensor de proximidade da tela.
Insira uma palheta de abertura sob o cabo do microfone, próximo ao microfone (o retângulo de metal).
Passe a palheta de abertura ao redor do microfone para separar seu adesivo.
Insira uma palheta de abertura sob o lado esquerdo do conjunto dos sensores frontais.
Passe a palheta sob o conjunto para separá-lo da estrutura.
Ferramenta utilizada neste passo:Tesa 61395 Tape$5.99
Remova o conjunto dos sensores frontais.
Conecte os sensores aos seus conectores na estrutura para ajudar a alinhar a seção principal do conjunto.
Use fita adesiva Tesa para colar novamente todas as partes do conjunto que não estejam mais colantes.
Compare a sua nova peça de reposição com a peça original. Pode ser que você precise transferir componentes remanescentes ou remover suportes adesivos da nova peça antes de instalá-la.
Para a remontagem de seu dispositivo, siga os passos acima na ordem inversa.
Leve o seu lixo eletrônico para um ponto de recolha ou uma recicladora certificada.
O reparo não está indo conforme o planejado? Tente soluções de problema básicas ou peça a ajuda da nossa comunidade de Respostas para o iPhone 13 Pro Max para solucionar os seus problemas.
37 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
93%
Udo Baingo está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
9 comentários
There is more to this repair than what you are showing. You aren’t showing us how and what to transfer off the old screen to the new one.
What components will need to be transferred over will depend on the replacement screen you receive. Some come with everything, some don't. I reference the parts iFixit sells when writing guides, and this guide will be updated if necessary once we have these screens in stock.
thanks for the article. I had a slightly different setup and your step 14 didn't address this and I tore one of the ribbon connectors that goes up tot the camera. I don't know what this is called so i don't know what to order. the ribbon that broke was the one disconnected in step 21. what is this and can it be replaced? thanks!
Hey. I changed my 13 pro max display, with the true tone and the auto brightness I also see that the display is not getting the maximum brightness level as supposed to. I see a big difference when I open the camera and switch between Video and Photo mode. Can it be fixed? Thank you!
Easy fix with a reprogramer
How do I change the true tone thanks?
Thanks for this guide. Every new iPhone as a different setup for the proximity sensor assembly so having a reference when doing an iPhone screen replacement makes me confident in doing each repair.
Write a glass only screen replacement for the iphone 13 pro max please.
Are waterproof seals part of the replacement kit, if not why?
Jim Langston - Responder
I ordered the screwdriver for the 13 ProMax (Y000) as well as the full kit which has this Y000 head. Neither tip works to remove the screws. Any suggestions?
Barbara Nuckles - Responder
