Ir para o conteúdo principal
Stihl BG 50 Pull Start Rope Replacement
Christian A.
Christian A. e um outro colaborador
Última atualização em December 21, 2021
10 - 20 minutos
Moderada
Use this guide to replace a broken or worn-down pull start rope from a Stihl BG 50 gas-powered leaf blower.
The purpose of the pull start rope is to start the combustion engine. The rope can become brittle if it is not used frequently or it may begin to tear after extensive use. If the rope is only dirty it is not necessary to replace it. If the rope has already broken, Step 2 can be skipped.
Be sure to removing the fuel from the blower’s fuel tank to prevent a fire hazard.
The old rope should be disposed of, but the pull start handle can be kept as a spare part.
  1. Stihl BG 50 Pull Start Rope Replacement, Pull Start Rope: passo 1, imagem 1 %32 Stihl BG 50 Pull Start Rope Replacement, Pull Start Rope: passo 1, imagem 2 %32
    • Use the Torx T25 screwdriver to remove the three screws holding the orange casing.
    • Remove the orange plastic casing from the rest of the blower.
  2. Stihl BG 50 Pull Start Rope Replacement: passo 2, imagem 1 %32 Stihl BG 50 Pull Start Rope Replacement: passo 2, imagem 2 %32
    • Hold the starter rope in a U shape.
    • Cut the rope with a knife without letting go of the rope going in the blower.
    • Letting go of the rope will make the rope pull itself rapidly into the starter pulley. This may damage other components.
  3. Stihl BG 50 Pull Start Rope Replacement: passo 3, imagem 1 %32 Stihl BG 50 Pull Start Rope Replacement: passo 3, imagem 2 %32
    • Let the rope go slowly into the starter pulley.
    • Grab the rope from its knot and remove the rope from the starter pulley.
  4. Stihl BG 50 Pull Start Rope Replacement: passo 4, imagem 1 %32
    • Tie a knot at the end of the new starter rope and set it aside.
  5. Stihl BG 50 Pull Start Rope Replacement: passo 5, imagem 1 %32
    • Spin the starter pulley clockwise until a noise is heard.
    • Letting go of the starter pulley will make it spin counter-clockwise. This may result in a small bruise or cut. To avoid this, make sure to have a strong grip on the starter pulley and spin it slowly.
  6. Stihl BG 50 Pull Start Rope Replacement: passo 6, imagem 1 %32 Stihl BG 50 Pull Start Rope Replacement: passo 6, imagem 2 %32 Stihl BG 50 Pull Start Rope Replacement: passo 6, imagem 3 %32
    • Having someone help to insert the rope through the holes will make these steps easier.
    • While holding the starter pulley, insert the end of the rope lacking the knot.
    • When it comes out the other side of the starter pulley, pull it through.
    • Without letting go of the starter pulley, insert the rope through the orange case and pull it taut.
  7. Stihl BG 50 Pull Start Rope Replacement: passo 7, imagem 1 %32 Stihl BG 50 Pull Start Rope Replacement: passo 7, imagem 2 %32
    • Hold the rope taut and let go of the starter pulley.
    • Let go of the rope slowly until about a foot of rope remains outside the casing.
  8. Stihl BG 50 Pull Start Rope Replacement: passo 8, imagem 1 %32 Stihl BG 50 Pull Start Rope Replacement: passo 8, imagem 2 %32 Stihl BG 50 Pull Start Rope Replacement: passo 8, imagem 3 %32
    • Insert the rope inside the pull start handle.
    • Tie a knot at the end of the rope.
    • Let go of the rope.
    • Make sure the pull start handle does not come off before letting go of the rope.
  9. Stihl BG 50 Pull Start Rope Replacement: passo 9, imagem 1 %32
    • Put the orange casing back on the blower.
    • Use the Torx T25 screwdriver to tighten the three screws.
Conclusão
When the pull start rope is pulled, it should wind back. If it does not, a mistake might have occurred when changing the new rope when winding it inside the starter pulley.
3 outras pessoas executaram este guia.
3 comentários
My cord works fine after disassembling fron blower. Put it back together and pulls a little way; then gets stuck, pull more rope,.but I can’t pull all the way out at one time to start the blower. Is there a problem with the wheel or motor
Lindauer93@gmail.com - Responder
Cord on blower won’t pull all the way out to start engine on big 50. Took it apart and pull rope pulls fine. Reassembled it and rope won’t pull all the way out to start.
I have a BG 55, 5.0mm cord too big...use the 3.0mm...fyi
Frankfordal - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 31
Últimos 30 dias: 143
Duração total: 7,817
