Ir para o conteúdo principal
Steam Deck Front Shell Replacement
O que você precisa
  1. Steam Deck Front Shell Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 1 %32 Steam Deck Front Shell Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 2 %32 Steam Deck Front Shell Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 3 %32
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    Pergunte ao FixBot
    Comentar
  2. Steam Deck Front Shell Replacement, Remove the back cover screws: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
    Pergunte ao FixBot
    Comentar
  3. Steam Deck Front Shell Replacement, Unclip the back cover: passo 3, imagem 1 %32 Steam Deck Front Shell Replacement, Unclip the back cover: passo 3, imagem 2 %32
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
    Pergunte ao FixBot
    Comentar
  4. Steam Deck Front Shell Replacement, Remove the back cover: passo 4, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the back cover: passo 4, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  5. Steam Deck Front Shell Replacement, Uncover the hidden shield screw: passo 5, imagem 1 %32 Steam Deck Front Shell Replacement, Uncover the hidden shield screw: passo 5, imagem 2 %32
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
    Pergunte ao FixBot
    Comentar
  6. Steam Deck Front Shell Replacement, Remove the shield screws: passo 6, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the shield screws: passo 6, imagem 2 %32
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
    Pergunte ao FixBot
    Comentar
  7. Steam Deck Front Shell Replacement, Remove the shield: passo 7, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the shield: passo 7, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the shield: passo 7, imagem 3 %32
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
    Pergunte ao FixBot
    Comentar
  8. Steam Deck Front Shell Replacement, Disconnect the battery: passo 8, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the battery: passo 8, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the battery: passo 8, imagem 3 %32
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
    Pergunte ao FixBot
    Comentar
  9. Steam Deck Front Shell Replacement, Unclip the left trigger: passo 9, imagem 1 %32 Steam Deck Front Shell Replacement, Unclip the left trigger: passo 9, imagem 2 %32
    • The left trigger will be on your right-hand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's left clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
    Pergunte ao FixBot
    Comentar
  10. Steam Deck Front Shell Replacement, Remove the left trigger: passo 10, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the left trigger: passo 10, imagem 2 %32
    • Remove the left trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
    Pergunte ao FixBot
    Comentar
  11. Steam Deck Front Shell Replacement, Remove the trigger bracket screws: passo 11, imagem 1 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the left trigger bracket.
    Pergunte ao FixBot
    Comentar
  12. Steam Deck Front Shell Replacement, Remove the trigger bracket: passo 12, imagem 1 %32
    • Remove the left trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
    Pergunte ao FixBot
    Comentar
  13. Steam Deck Front Shell Replacement, Disconnect the left thumbstick: passo 13, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the left thumbstick: passo 13, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the left thumbstick: passo 13, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
    Pergunte ao FixBot
    Comentar
  14. Steam Deck Front Shell Replacement, Remove the thumbstick screws: passo 14, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the thumbstick screws: passo 14, imagem 2 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
    Pergunte ao FixBot
    Comentar
  15. Steam Deck Front Shell Replacement, Remove the left thumbstick: passo 15, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the left thumbstick: passo 15, imagem 2 %32
    • Remove the left thumbstick.
    Pergunte ao FixBot
    Comentar
  16. Steam Deck Front Shell Replacement, Disconnect the interconnect cable: passo 16, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the interconnect cable: passo 16, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the interconnect cable: passo 16, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  17. Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: passo 17, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: passo 17, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: passo 17, imagem 3 %32
    • If any connectors are covered with tape, use a pair of tweezers to remove it.
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the D-pad cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
    Pergunte ao FixBot
    Comentar
  18. Steam Deck Front Shell Replacement, Disconnect the left haptics: passo 18, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the left haptics: passo 18, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the left haptics: passo 18, imagem 3 %32
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
    • Alternatively, you can leave the haptics connected to the button board and flip the board up and over the edge of the shell and out of the way.
    Pergunte ao FixBot
    Comentar
  19. Steam Deck Front Shell Replacement, Remove the button board screws: passo 19, imagem 1 %32
    • Use a Phillips driver to disconnect the four screws securing the left button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
    Pergunte ao FixBot
    Comentar
  20. Steam Deck Front Shell Replacement, Remove the button board: passo 20, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the button board: passo 20, imagem 2 %32
    • Remove the left button board.
    • Keep track of the Steam button and its membrane, as once the left button board is removed, they're no longer secured in place.
    Pergunte ao FixBot
    Comentar
  21. Steam Deck Front Shell Replacement, Remove the touchpad board screws: passo 21, imagem 1 %32
    • Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad board.
    Pergunte ao FixBot
    Comentar
  22. Steam Deck Front Shell Replacement, Remove the touchpad board: passo 22, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the touchpad board: passo 22, imagem 2 %32
    • Remove the touchpad board.
    Pergunte ao FixBot
    Comentar
  23. Steam Deck Front Shell Replacement, Remove the touchpad screws: passo 23, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the touchpad screws: passo 23, imagem 2 %32
    • Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad.
    • You may need to temporarily remove the Steam button membrane for easier access to the bottom left screw.
    • Each of the touchpad's four mounting corners have a locating peg. During reassembly, ensure each is properly seated.
    Pergunte ao FixBot
    Comentar
  24. Steam Deck Front Shell Replacement, Remove the left touchpad: passo 24, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the left touchpad: passo 24, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the left touchpad: passo 24, imagem 3 %32
    • The touchpad's springs are very delicate and are precisely positioned. If bent, the touchpad may rattle or not work as intended.
    • From the front of the Steam Deck, use your finger to push the left touchpad partway through the front shell to unseat it.
    • Lift the touchpad out from underneath the overhanging section of the midframe.
    • Remove the touchpad.
    Pergunte ao FixBot
    Comentar
  25. Steam Deck Front Shell Replacement, Unclip the right trigger: passo 25, imagem 1 %32 Steam Deck Front Shell Replacement, Unclip the right trigger: passo 25, imagem 2 %32
    • The right trigger will be on your left-hand side when working on the Steam Deck, as it's laying upside down.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    Pergunte ao FixBot
    Comentar
  26. Steam Deck Front Shell Replacement, Remove the right trigger: passo 26, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the right trigger: passo 26, imagem 2 %32
    • Remove the right trigger.
    Pergunte ao FixBot
    Comentar
  27. Steam Deck Front Shell Replacement, Remove the trigger bracket screws: passo 27, imagem 1 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
    Pergunte ao FixBot
    Comentar
  28. Steam Deck Front Shell Replacement, Remove the trigger bracket: passo 28, imagem 1 %32
    • Remove the right trigger bracket.
    Pergunte ao FixBot
    Comentar
  29. Steam Deck Front Shell Replacement, Disconnect the right thumbstick: passo 29, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the right thumbstick: passo 29, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the right thumbstick: passo 29, imagem 3 %32
    Pergunte ao FixBot
    Comentar
  30. Steam Deck Front Shell Replacement, Remove the thumbstick screws: passo 30, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the thumbstick screws: passo 30, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  31. Steam Deck Front Shell Replacement, Remove the right thumbstick: passo 31, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the right thumbstick: passo 31, imagem 2 %32
    • Remove the right thumbstick.
    Pergunte ao FixBot
    Comentar
  32. Steam Deck Front Shell Replacement, Disconnect the button board cable: passo 32, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the button board cable: passo 32, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the button board cable: passo 32, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  33. Steam Deck Front Shell Replacement, Disconnect the interconnect cable: passo 33, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the interconnect cable: passo 33, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the interconnect cable: passo 33, imagem 3 %32
    Pergunte ao FixBot
    Comentar
  34. Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: passo 34, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: passo 34, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: passo 34, imagem 3 %32
    • Disconnect the action buttons cable.
    Pergunte ao FixBot
    Comentar
  35. Steam Deck Front Shell Replacement, Disconnect the right haptics: passo 35, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the right haptics: passo 35, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the right haptics: passo 35, imagem 3 %32
    Pergunte ao FixBot
    Comentar
  36. Steam Deck Front Shell Replacement, Remove the button board screws: passo 36, imagem 1 %32
    • Use a Phillips driver to disconnect the four screws securing the right button board:
    • One 3.9 mm screw
    Pergunte ao FixBot
    Comentar
  37. Steam Deck Front Shell Replacement, Remove the button board: passo 37, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the button board: passo 37, imagem 2 %32
    • Remove the right button board.
    • Keep track of the quick access button and its membrane, as once the right button board is removed, they're no longer secured in place.
    Pergunte ao FixBot
    Comentar
  38. Steam Deck Front Shell Replacement, Remove the touchpad board screws: passo 38, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  39. Steam Deck Front Shell Replacement, Remove the touchpad board: passo 39, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the touchpad board: passo 39, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  40. Steam Deck Front Shell Replacement, Remove the touchpad screws: passo 40, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the touchpad screws: passo 40, imagem 2 %32
    • You may need to temporarily remove the quick access button membrane for easier access to the bottom right screw.
    Pergunte ao FixBot
    Comentar
  41. Steam Deck Front Shell Replacement, Remove the right touchpad: passo 41, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the right touchpad: passo 41, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the right touchpad: passo 41, imagem 3 %32
    • From the front of the Steam Deck, use your finger to push the right touchpad partway through the front shell to unseat it.
    Pergunte ao FixBot
    Comentar
  42. Steam Deck Front Shell Replacement, Remove the quick access button membrane: passo 42, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the quick access button membrane: passo 42, imagem 2 %32
    • Use a pair of tweezers to remove the quick access button membrane.
    Pergunte ao FixBot
    Comentar
  43. Steam Deck Front Shell Replacement, Remove the quick access button: passo 43, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the quick access button: passo 43, imagem 2 %32
    • Use a pair of tweezers to remove the quick access button.
    Pergunte ao FixBot
    Comentar
  44. Steam Deck Front Shell Replacement, Remove the Steam button membrane: passo 44, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the Steam button membrane: passo 44, imagem 2 %32
    • Use a pair of tweezers to remove the Steam button membrane.
    Pergunte ao FixBot
    Comentar
  45. Steam Deck Front Shell Replacement, Remove the Steam button: passo 45, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the Steam button: passo 45, imagem 2 %32
    • Use a pair of tweezers to remove the Steam button.
    Pergunte ao FixBot
    Comentar
  46. Steam Deck Front Shell Replacement, Remove the SSD screw: passo 46, imagem 1 %32
    • Use a Phillips driver to remove the 3.4 mm screw securing the SSD.
    Pergunte ao FixBot
    Comentar
  47. Steam Deck Front Shell Replacement, Remove the SSD: passo 47, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the SSD: passo 47, imagem 2 %32
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
    Pergunte ao FixBot
    Comentar
  48. Steam Deck Front Shell Replacement, Remove the heatsink sticker: passo 48, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the heatsink sticker: passo 48, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the heatsink sticker: passo 48, imagem 3 %32
    • Use a pair of tweezers to remove the sticker from the top edge of the fan.
    • If possible, try not to rip or tear this sticker so it can be reused. Use a little bit of heat if necessary to soften the adhesive.
    Pergunte ao FixBot
    Comentar
  49. Steam Deck Front Shell Replacement, Remove the heatsink screws: passo 49, imagem 1 %32
    • Use a Phillips driver to loosen and remove the two screws securing the heatsink to the motherboard:
    • One captive 3.5 mm screw
    • One 3.4 mm screw
    • No, your eyes don't deceive you! The third heatsink screw was removed earlier in the disassembly: it doubles as the hidden board shield screw.
    Pergunte ao FixBot
    Comentar
  50. Steam Deck Front Shell Replacement, Remove the heatsink: passo 50, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the heatsink: passo 50, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the heatsink: passo 50, imagem 3 %32
    • Lift and remove the heatsink.
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and APU and reapply thermal paste.
    Pergunte ao FixBot
    Comentar
  51. Steam Deck Front Shell Replacement, Disconnect the fan: passo 51, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the fan: passo 51, imagem 2 %32
    • Use a pair of tweezers to grip the edges of the fan connector and pull up to disconnect it from the motherboard.
    • Pull the fan cable by its connector, not the wires themselves.
    Pergunte ao FixBot
    Comentar
  52. Steam Deck Front Shell Replacement, Remove the fan screws: passo 52, imagem 1 %32
    • Use a Phillips driver to remove the two 3.7 mm screws securing the fan.
    • The other two fan screws were removed earlier in the disassembly: they double as two back cover screws.
    Pergunte ao FixBot
    Comentar
  53. Steam Deck Front Shell Replacement, Remove the fan: passo 53, imagem 1 %32
    • Remove the fan.
    Pergunte ao FixBot
    Comentar
  54. Steam Deck Front Shell Replacement, Disconnect the speakers: passo 54, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the speakers: passo 54, imagem 2 %32
    • Use a pair of tweezers to grip the edges of the speaker connector and pull up to disconnect it from the motherboard.
    • Pull the speaker cable by its connector, not the wires themselves.
    Pergunte ao FixBot
    Comentar
  55. Steam Deck Front Shell Replacement, Remove the Wi-Fi shield tape: passo 55, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the Wi-Fi shield tape: passo 55, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the Wi-Fi shield tape: passo 55, imagem 3 %32
    • Use a pair of tweezers to peel up and remove the Wi-Fi shield tape.
    Pergunte ao FixBot
    Comentar
  56. Steam Deck Front Shell Replacement, Disconnect the Wi-Fi: passo 56, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the Wi-Fi: passo 56, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the Wi-Fi: passo 56, imagem 3 %32
    • Use a pair of tweezers to grip the antenna connector close to its base.
    • Pull straight up to disconnect the cable.
    • Repeat for the second antenna cable.
    • During reassembly, ensure that both antenna cables are reconnected at their appropriate connectors. The labels on the cables match the markings on the Wi-Fi module.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
    Pergunte ao FixBot
    Comentar
  57. Steam Deck Front Shell Replacement, Disconnect the display: passo 57, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the display: passo 57, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the display: passo 57, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the display cable's ZIF connector.
    • Grip the cable by the pull tab, not by the cable itself.
    Pergunte ao FixBot
    Comentar
  58. Steam Deck Front Shell Replacement, Disconnect the audio cable: passo 58, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the audio cable: passo 58, imagem 2 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the audio cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  59. Steam Deck Front Shell Replacement: passo 59, imagem 1 %32 Steam Deck Front Shell Replacement: passo 59, imagem 2 %32
    • Grip the cable by its pull tab, not by the cable itself.
    Pergunte ao FixBot
    Comentar
  60. Steam Deck Front Shell Replacement: passo 60, imagem 1 %32 Steam Deck Front Shell Replacement: passo 60, imagem 2 %32 Steam Deck Front Shell Replacement: passo 60, imagem 3 %32
    • Carefully peel the audio cable off of the battery.
    • The audio cable is secured to the battery with some light adhesive.
    • If the adhesive is stubborn, don't force the cable. Lightly heat the audio cable using an iOpener or a hair dryer to soften the adhesive.
    Pergunte ao FixBot
    Comentar
  61. Steam Deck Front Shell Replacement, Remove the motherboard screws: passo 61, imagem 1 %32
    • Use a Phillips driver to remove the three 3.7 mm screws securing the motherboard.
    Pergunte ao FixBot
    Comentar
  62. Steam Deck Front Shell Replacement, Remove the motherboard: passo 62, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the motherboard: passo 62, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the motherboard: passo 62, imagem 3 %32
    • Remove the motherboard.
    • The audio and button board cables attach to the underside of the motherboard with ZIF connectors.
    Pergunte ao FixBot
    Comentar
  63. Steam Deck Front Shell Replacement, Disconnect the mic cable: passo 63, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the mic cable: passo 63, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the mic cable: passo 63, imagem 3 %32
    • Use the pointed end of a spudger to lift up on the mic cable's white locking tab.
    • You should feel a small tactile bump once the connector unlocks.
    • Use a pair of tweezers to pull the mic cable up and out of its connector.
    • With the connector properly unlocked, the mic cable should slide out with little to no resistance.
    • During reassembly, ensure that the locking tab is in its unlocked, lifted position before reinserting the mic cable. Press down on the tab to lock the cable in place.
    Pergunte ao FixBot
    Comentar
  64. Steam Deck Front Shell Replacement, Remove the audio board screws: passo 64, imagem 1 %32
    • Use a Phillips driver to remove the two 3.7 mm screws securing the audio board.
    Pergunte ao FixBot
    Comentar
  65. Steam Deck Front Shell Replacement, Remove the audio board: passo 65, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the audio board: passo 65, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the audio board: passo 65, imagem 3 %32
    • Use a pair of tweezers to grip the audio board by the headphone jack.
    • Pivot the board up and out of its recess to remove it.
    Pergunte ao FixBot
    Comentar
  66. Steam Deck Front Shell Replacement, Isolate the speaker wire: passo 66, imagem 1 %32
    • Use a pair of tweezers to peel up the tape bundling the speaker wire to the Wi-Fi antenna cables.
    Pergunte ao FixBot
    Comentar
  67. Steam Deck Front Shell Replacement: passo 67, imagem 1 %32 Steam Deck Front Shell Replacement: passo 67, imagem 2 %32 Steam Deck Front Shell Replacement: passo 67, imagem 3 %32
    • Use a pair of tweezers to peel up the various strips of black tape routing the speaker wire along the bottom edge of the chassis.
    Pergunte ao FixBot
    Comentar
  68. Steam Deck Front Shell Replacement, Remove the right speaker: passo 68, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the right speaker: passo 68, imagem 2 %32
    • Insert the flat end of a spudger between the right speaker and the frame.
    • Pivot the spudger up to separate the speaker from the light adhesive securing it against the front shell.
    • If the adhesive is stubborn, don't force the speaker out. Lightly heat it using an iOpener or a hair dryer to soften the adhesive underneath.
    Pergunte ao FixBot
    Comentar
  69. Steam Deck Front Shell Replacement: passo 69, imagem 1 %32 Steam Deck Front Shell Replacement: passo 69, imagem 2 %32
    • Use a pair of tweezers to grip and remove the right speaker from its cavity.
    Pergunte ao FixBot
    Comentar
  70. Steam Deck Front Shell Replacement, Remove the left speaker: passo 70, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the left speaker: passo 70, imagem 2 %32
    • Insert the flat end of a spudger between the left speaker and the frame.
    Pergunte ao FixBot
    Comentar
  71. Steam Deck Front Shell Replacement: passo 71, imagem 1 %32 Steam Deck Front Shell Replacement: passo 71, imagem 2 %32
    • Use a pair of tweezers to grip and remove the left speaker from its cavity.
    Pergunte ao FixBot
    Comentar
  72. Steam Deck Front Shell Replacement, Remove the speakers: passo 72, imagem 1 %32
    • Remove the tethered right and left speakers.
    Pergunte ao FixBot
    Comentar
  73. Steam Deck Front Shell Replacement, Uncover the display connector: passo 73, imagem 1 %32 Steam Deck Front Shell Replacement, Uncover the display connector: passo 73, imagem 2 %32
    • Use a pair of tweezers to peel back the sticker covering the display connector.
    Pergunte ao FixBot
    Comentar
  74. Steam Deck Front Shell Replacement, Disconnect the display: passo 74, imagem 1 %32 Steam Deck Front Shell Replacement, Disconnect the display: passo 74, imagem 2 %32 Steam Deck Front Shell Replacement, Disconnect the display: passo 74, imagem 3 %32
    Pergunte ao FixBot
    Comentar
  75. Steam Deck Front Shell Replacement, Heat the display adhesive: passo 75, imagem 1 %32
    • Prepare an iOpener and apply it to the top edge of the display for one minute.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the Steam Deck—displays and internal batteries are both susceptible to heat damage.
    Pergunte ao FixBot
    Comentar
  76. Steam Deck Front Shell Replacement, Insert an opening pick: passo 76, imagem 1 %32 Steam Deck Front Shell Replacement, Insert an opening pick: passo 76, imagem 2 %32 Steam Deck Front Shell Replacement, Insert an opening pick: passo 76, imagem 3 %32
    • Apply a suction cup to the top left corner of the display by pressing down on it to create suction, as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken glass.
    • Pull up on the suction cup with strong, steady force to create a gap between the display and the frame.
    • Insert the point of an opening pick into the gap.
    • Don't insert the pick more than 1/8 of an inch (~3 mm) or you risk damaging the display panel, ambient light sensor, or fragile cable underneath.
    Pergunte ao FixBot
    Comentar
  77. Steam Deck Front Shell Replacement, Begin to slice the adhesive: passo 77, imagem 1 %32 Steam Deck Front Shell Replacement, Begin to slice the adhesive: passo 77, imagem 2 %32 Steam Deck Front Shell Replacement, Begin to slice the adhesive: passo 77, imagem 3 %32
    • Slide the opening pick no more than 3 mm deep across the top edge to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  78. Steam Deck Front Shell Replacement, Heat the display adhesive: passo 78, imagem 1 %32
    • Heat the right edge of the display for one minute.
    Pergunte ao FixBot
    Comentar
  79. Steam Deck Front Shell Replacement, Slice the right side adhesive: passo 79, imagem 1 %32 Steam Deck Front Shell Replacement, Slice the right side adhesive: passo 79, imagem 2 %32 Steam Deck Front Shell Replacement, Slice the right side adhesive: passo 79, imagem 3 %32
    • Slide the opening pick down the right edge to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  80. Steam Deck Front Shell Replacement, Heat the display adhesive: passo 80, imagem 1 %32
    • Heat the bottom edge of the display for one minute.
    Pergunte ao FixBot
    Comentar
  81. Steam Deck Front Shell Replacement, Slice the bottom side adhesive: passo 81, imagem 1 %32 Steam Deck Front Shell Replacement, Slice the bottom side adhesive: passo 81, imagem 2 %32 Steam Deck Front Shell Replacement, Slice the bottom side adhesive: passo 81, imagem 3 %32
    • Slide the opening pick across the bottom edge to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  82. Steam Deck Front Shell Replacement, Heat the display adhesive: passo 82, imagem 1 %32
    • Heat the left edge of the display for one minute.
    • Slide the opening pick across the left edge to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  83. Steam Deck Front Shell Replacement, Lift up the display: passo 83, imagem 1 %32 Steam Deck Front Shell Replacement, Lift up the display: passo 83, imagem 2 %32 Steam Deck Front Shell Replacement, Lift up the display: passo 83, imagem 3 %32
    • Once you have sliced around the perimeter of the display, carefully lift the right edge up, opening it like a book.
    • Remove the display.
    • During reassembly, if you’d like to install new display adhesive strips, follow these steps after removing your old adhesive strips from your current display.
    Pergunte ao FixBot
    Comentar
  84. Steam Deck Front Shell Replacement, Remove the bumper screws: passo 84, imagem 1 %32
    • Use a Phillips driver to remove the two 5.2 mm screws securing the left bumper assembly.
    Pergunte ao FixBot
    Comentar
  85. Steam Deck Front Shell Replacement, Remove the left bumper assembly: passo 85, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the left bumper assembly: passo 85, imagem 2 %32
    • Remove the left bumper assembly.
    Pergunte ao FixBot
    Comentar
  86. Steam Deck Front Shell Replacement, Remove the bumper screws: passo 86, imagem 1 %32
    • Use a Phillips driver to remove the two 5.2 mm screws securing the right bumper assembly.
    Pergunte ao FixBot
    Comentar
  87. Steam Deck Front Shell Replacement, Remove the right bumper assembly: passo 87, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the right bumper assembly: passo 87, imagem 2 %32
    • Remove the right bumper assembly.
    Pergunte ao FixBot
    Comentar
  88. Steam Deck Front Shell Replacement, Remove the D-pad membrane: passo 88, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the D-pad membrane: passo 88, imagem 2 %32
    • Use a pair of tweezers to remove the D-pad membrane.
    Pergunte ao FixBot
    Comentar
  89. Steam Deck Front Shell Replacement, Remove the D-pad: passo 89, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the D-pad: passo 89, imagem 2 %32
    • Use a pair of tweezers to remove the D-pad.
    • During reassembly, align the D-pad button such that the short side is facing towards the Steam Deck's outer edge.
    Pergunte ao FixBot
    Comentar
  90. Steam Deck Front Shell Replacement, Remove the action buttons membrane: passo 90, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the action buttons membrane: passo 90, imagem 2 %32
    • Use a pair of tweezers to remove the action buttons membrane.
    Pergunte ao FixBot
    Comentar
  91. Steam Deck Front Shell Replacement, Remove the action buttons: passo 91, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the action buttons: passo 91, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the action buttons: passo 91, imagem 3 %32
    • Use a pair of tweezers to remove the four action buttons, A, B, X, and Y.
    • During reassembly, don't worry! The buttons are keyed—they can only be reinstalled in one orientation.
    Pergunte ao FixBot
    Comentar
  92. Steam Deck Front Shell Replacement, Remove the view button: passo 92, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the view button: passo 92, imagem 2 %32
    • Use a pair of tweezers to remove the view button.
    Pergunte ao FixBot
    Comentar
  93. Steam Deck Front Shell Replacement, Remove the menu button: passo 93, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the menu button: passo 93, imagem 2 %32
    • Use a pair of tweezers to remove the menu button.
    Pergunte ao FixBot
    Comentar
  94. Steam Deck Front Shell Replacement, Remove the front midframe screws: passo 94, imagem 1 %32
    • Use a Phillips driver to remove the six 2.3 mm screws securing the midframe to the front shell, located on the front side.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different Phillips driver if the screws won't come out.
    Pergunte ao FixBot
    Comentar
  95. Steam Deck Front Shell Replacement, Remove the rear midframe screws: passo 95, imagem 1 %32
    • Use a Phillips driver to remove the four 5.2 mm screws securing the midframe to the front shell.
    Pergunte ao FixBot
    Comentar
  96. Steam Deck Front Shell Replacement, Remove the midframe: passo 96, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the midframe: passo 96, imagem 2 %32
    • Remove the midframe.
    Pergunte ao FixBot
    Comentar
  97. Steam Deck Front Shell Replacement: passo 97, imagem 1 %32 Steam Deck Front Shell Replacement: passo 97, imagem 2 %32
    • Use the pointed end of a spudger to lift the rubber flap to the left of the volume buttons up and out of its plastic clip.
    Pergunte ao FixBot
    Comentar
  98. Steam Deck Front Shell Replacement, Remove the volume buttons: passo 98, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the volume buttons: passo 98, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the volume buttons: passo 98, imagem 3 %32
    • Use a pair of tweezers to remove the volume buttons by pulling them up and away from the front shell.
    Pergunte ao FixBot
    Comentar
  99. Steam Deck Front Shell Replacement: passo 99, imagem 1 %32 Steam Deck Front Shell Replacement: passo 99, imagem 2 %32
    • Use the pointed end of a spudger to lift the rubber flap to the right of the power button up and out of its plastic clip.
    Pergunte ao FixBot
    Comentar
  100. Steam Deck Front Shell Replacement, Remove the power button: passo 100, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the power button: passo 100, imagem 2 %32 Steam Deck Front Shell Replacement, Remove the power button: passo 100, imagem 3 %32
    • Use the pointed end of a spudger to lift the rubber flap to the left of the power button up and out of its plastic clip.
    • Remove the power button.
    Pergunte ao FixBot
    Comentar
  101. Steam Deck Front Shell Replacement: passo 101, imagem 1 %32 Steam Deck Front Shell Replacement: passo 101, imagem 2 %32
    • Insert the flat end of a spudger under the left end of the mic cable and pry upwards to peel it up from the front shell.
    • The mic cable is secured to the front shell with some light adhesive.
    • If the adhesive is stubborn, don't force the cable. Lightly heat the mic cable using an iOpener or a hair dryer to soften the adhesive.
    Pergunte ao FixBot
    Comentar
  102. Steam Deck Front Shell Replacement: passo 102, imagem 1 %32 Steam Deck Front Shell Replacement: passo 102, imagem 2 %32 Steam Deck Front Shell Replacement: passo 102, imagem 3 %32
    • Insert the flat end of a spudger under the right end of the mic cable and pry upwards to peel it up from the front shell.
    Pergunte ao FixBot
    Comentar
  103. Steam Deck Front Shell Replacement, Remove the mic cable: passo 103, imagem 1 %32 Steam Deck Front Shell Replacement, Remove the mic cable: passo 103, imagem 2 %32
    • Remove the mic cable from the front shell.
    • Only the front shell remains.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
24 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
167.292 Reputação
Autoria de 439 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.226 guias
20Comentários do guia
maybe I don’t need an Atomic Purple replacement shell…
Jon - Responder Compartilhar
Hahaha. Same
Rob - Responder Compartilhar
Same, wouldn't have minded a sweet water dipped or translucent outer shell. Bring back that mad catz/third party aesthetic.
Ichi Yamamoto - Responder Compartilhar
I wanted to replace my old shell with a new one cause it got scratches... well, now I feel the scratches ain't that ugly.
Milo Zhao - Responder Compartilhar
Seems to me like a "Welp...I guess if I ever break the screen and have to replace it, that's when I'll get an atomic purple shell...
reginalb124 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 30
Últimos 7 dias: 279
Últimos 30 dias: 1,338
Ao todo: 69,548
