Ir para o conteúdo principal
Stapler Maintenance
Stapler Maintenance
Sequoia Equities
Sequoia Equities e 5 outros colaboradores
Última atualização em August 30, 2024
20 segundos - 1 minuto
Moderado
Guia colaborativo
Introdução
Ir para o passo 1
Use this guide to refill and empty stapler, so you can get back to those TPS reports.
  1. Stapler Maintenance, Open & Identify: passo 1, imagem 1 %32 Stapler Maintenance, Open & Identify: passo 1, imagem 2 %32
    • Be careful while handling staples or any sharp object in general.
    • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
    • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
  2. Stapler Maintenance, Insert Staples: passo 2, imagem 1 %32 Stapler Maintenance, Insert Staples: passo 2, imagem 2 %32
    • Get a cluster of staples and carefully place it in the carrier.
    • Make sure there is enough room for the pusher to contact the staples.
    • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
  3. Stapler Maintenance: passo 3, imagem 1 %32
    • Don’t staple your hand, or anyone else for that matter.
    • Congratulations! You have successfully replaced staples in your stapler.
Conclusão
7 outras pessoas executaram este guia.
2Comentários do guia
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - Responder
@ cookie clicker When I attempted to load the staples, the spring became detached. However, I'm unsure where to reattach it, and I now have a loose, short plastic rod.
Nadia Eira - Responder
Comentar
Visualizações:
Últimas 24 horas: 46
Últimos 7 dias: 272
Últimos 30 dias: 1,319
Ao todo: 28,074
