Sony Cyber-shot DSC-HX80 LCD Screen Replacement
Introdução
Ir para o passo 1In the event of a damaged LCD screen, the only option may be for you to replace it. The following guide will take you step by step through the process.
O que você precisa
Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
Flip LCD screen upwards.
Use the PH000 Phillips head screwdriver to remove the two 0.3 mm Phillips black screws located on the sides of the LCD screen. Place screws on magnetic mat or plastic bag.
To complete this repair, I need the connecting piece behind the LCD. Do you have that piece if not wjere can Iget it or canyou get it for
To complete this repair, I need the connecting piece behind the LCD. Do you have that piece if not wjere can Iget it or canyou get it for me
Use a nylon spudger to gently remove the damaged LCD screen off the camera.
Replace LCD screen with new one.
Whst is the name of the connecting ribbons piece at the back of the LCD. On my camera ..Sony hx 80, the end of that piece that connects it to the camera is broken. Do you have that part? If not, where can I get it..reply to….frango@rogers.com…I am in Canada. THANKS.
2 more photos showing the removal of the cables and then their reattachment would earn the author points.
I agree, this how-to is skipping the hard part. Just busted one of the ribbon cables 😔
4 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all7Comentários do guia
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Hello could you show a picture of where exactly under the flash has to be the magnetite tangle. Thanks.
Wolfina -
Anyone know where I can find the cable from the screen to the camera?
same question here! i repalced the lcd thinking that was the problem but the lcd is still black. the viewfinder works fine so i think i need to replace the cable that goes from the camera to the screen. any info?
where can i find the screen other then threw sony
Im looking for lcd screen for sony dsc hx80 on back TX08D155HMOAAA. A9N9I523946
Looking for replacement lcd screen fo sony dsc hx80 screen # on back is. TXO8D155HMOAAA. A9N9I523946
