Ir para o conteúdo principal
Sony Cyber-Shot DSC-W830 LCD Replacement
Addyson Salalila
Addyson Salalila e 5 outros colaboradores
Última atualização em December 24, 2016
10 minutos
Moderado
Introdução
Ir para o passo 1
This will show you how to disassemble the camera and show you how to safely and successfully remove the LCD.
O que você precisa
Ferramentas
Exibir mais…
  1. Sony Cyber-Shot DSC-W830 LCD Replacement, Battery: passo 1, imagem 1 %32
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 2, imagem 1 %32
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 3, imagem 1 %32
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: passo 4, imagem 1 %32 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: passo 4, imagem 2 %32 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: passo 4, imagem 3 %32
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 5, imagem 1 %32 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 5, imagem 2 %32 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 5, imagem 3 %32
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
    There is also a small corner piece, coloured the same as camera body, at the battery compartment corner which will also fall out. be careful not to loose it - it’s a bit fidly to fit back when re-assembling, but logcal. The Ifixit tweezers where a great help in locating it back on its pins.
    Nicholas Smith - Responder
  6. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 6, imagem 1 %32 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 6, imagem 2 %32 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 6, imagem 3 %32
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: passo 7, imagem 1 %32 Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: passo 7, imagem 2 %32
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 8, imagem 1 %32 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 8, imagem 2 %32
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: passo 9, imagem 1 %32 Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: passo 9, imagem 2 %32
    • Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
    • Be careful when lifting the LCD screen; the ribbon cable will still be attached.
  10. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 10, imagem 1 %32 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 10, imagem 2 %32
    • Grasp the no-fuss ribbon cable and gently pull it out from the motherboard.
Conclusão
4 outras pessoas executaram este guia.
Addyson Salalila
Membro desde: 09/15/16
313 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 17-1, Blackwell Fall 2016 Membro de USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Membros
Autoria de 6 guias
5Comentários do guia
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
tajbhatnagar - Responder
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Tamil Varshitha - Responder
Sony dsc s2000 model camera need
Display & lens unit
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 71
Ao todo: 4,800
