Ir para o conteúdo principal
Sony CPF-IP001 Buttons on Main Speaker Replacement
Cole Stanley
Cole Stanley e 4 outros colaboradores
Última atualização em June 25, 2015
45 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to replace the function and volume buttons on the top of the speakers if they are broken.
O que você precisa
Ferramentas
Exibir mais…
  1. Sony CPF-IP001 Buttons on Main Speaker Replacement, Main Speaker Housing Disassembly: passo 1, imagem 1 %32
    • Remove two 6mm Phillips #0 screws.
    • Remove two 7.5 mm Phillips #0 screws.
    • Remove seven 4 mm Phillips #0 screws.
  2. Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 2, imagem 1 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 2, imagem 2 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 2, imagem 3 %32
    • Remove six 4 mm Phillips #0 screws from the metal backing.
    • Remove six 5 mm Phillips #0 screws from the metal backing.
    • Using the plastic opening tool, remove the metal plate from the main speaker by gently pulling on it.
  3. Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 3, imagem 1 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 3, imagem 2 %32
    • Remove the plastic dock cover by using two fingers to push the attached metal piece forward and slide it out of the holes.
  4. Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 4, imagem 1 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 4, imagem 2 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using the plastic opening tool, detach the wires connected to the metal plate
    • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
    • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
    • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
    • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
    • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
  5. Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 5, imagem 1 %32
    • Remove two 5 mm Phillips #0 screws.
  6. Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 6, imagem 1 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 6, imagem 2 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 6, imagem 3 %32
    • Using the metal spudger, loosen the metal cap at the end of the speaker.
    • Slide down the loosened cap to remove it from the end of the speaker.
    • Simultaneously push down on the buttons and slide the speaker out from the casing.
  7. Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: passo 7, imagem 1 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: passo 7, imagem 2 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: passo 7, imagem 3 %32
    • Remove two 6 mm Phillips #0 screws.
    • Gently lift the silver buttons up to remove.
  8. Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 8, imagem 1 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 8, imagem 2 %32 Sony CPF-IP001 Buttons on Main Speaker Replacement: passo 8, imagem 3 %32
    • Using the plastic opening tool, disconnect the white connector from the circuit board.
    • Replace the broken circuit board with a new one.
Conclusão
3 outras pessoas executaram este guia.
Cole Stanley
Membro desde: 04/14/15
290 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-14, Maness Spring 2015 Membro de Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 Membros
Autoria de 8 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 345
