Ir para o conteúdo principal
Sew a Button
Sew a Button
Brittany McCrigler
Brittany McCrigler e 6 outros colaboradores
Última atualização em April 23, 2025
10 - 15 minutos
Fácil
Guia em destaque
Patagonia
Introdução
Ir para o passo 1
Replacing a button is one of the most common clothing repairs. Fortunately, it's also one of the easiest. This guide will show you how to reattach a standard four-hole button with a needle and thread. In this guide we're using contrasting thread for visibility, but when it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Sew a Button, Sew a Button: passo 1, imagem 1 %32
    • Locate the area where the button has gone missing.
    Tailor's chalk is optional. Unnecessary to buy if you don't have it already. You can mark the location on the underside with your finger or lightly with any pointy object such as a pen. Stick the needle through a little and double check the location. If off then pull the needle back and retry, no harm done.
    The parts list should also include: Needle.
    Fixbert Fixstein - Responder
  2. Sew a Button: passo 2, imagem 1 %32 Sew a Button: passo 2, imagem 2 %32
    • Overlap the buttonhole with where the button should be. Going through the buttonhole, mark the fabric below with tailor's chalk.
  3. Sew a Button: passo 3, imagem 1 %32 Sew a Button: passo 3, imagem 2 %32
    • Get a length of thread—about an arms-length should be more than enough.
    • Thread a needle.
    You can use common cotton thread found in most basic sewing kits, but for a stronger, more durable repair you might consider "button thread". It is a cotton-blend thread that is a bit thicker and stronger due to the polyester content.
    It can be found in any good craft or fabric shop and is only about 50 cents more than the average spool of common thread.
    Matt - Responder
    Thread color: if you have many too a choose from pick a thread similar to that in the other buttons. But if not then use any thread at hand on the spot, you can always redo the button later.
  4. Sew a Button: passo 4, imagem 1 %32 Sew a Button: passo 4, imagem 2 %32 Sew a Button: passo 4, imagem 3 %32
    • Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle.
    • Tie the loose ends of the thread together.
  5. Sew a Button: passo 5, imagem 1 %32 Sew a Button: passo 5, imagem 2 %32
    • Tie a second regular knot over the first one to make it bigger. You don't want the thread slipping right through the grain of the fabric.
  6. Sew a Button: passo 6, imagem 1 %32 Sew a Button: passo 6, imagem 2 %32 Sew a Button: passo 6, imagem 3 %32
    • Poke the needle up through the chalk mark from the underside of the fabric.
    • Pull the thread taut, until the knot catches the backside of the fabric.
  7. Sew a Button: passo 7, imagem 1 %32 Sew a Button: passo 7, imagem 2 %32
    • Thread the needle through one hole of the button. You can pick any hole to start with.
    • Let the button drop all the way down onto the fabric.
  8. Sew a Button: passo 8, imagem 1 %32 Sew a Button: passo 8, imagem 2 %32 Sew a Button: passo 8, imagem 3 %32
    • Push the needle through the buttonhole directly opposite the one you have already threaded.
    • Be sure to go through only the button, not the fabric.
    Which order to go up/down through the button holes: This can vary (diagonally vs one step to the side) so just look at the shirt's existing buttons and mimic that to get the most consistent look.
  9. Sew a Button: passo 9, imagem 1 %32 Sew a Button: passo 9, imagem 2 %32 Sew a Button: passo 9, imagem 3 %32
    • Push the needle back through the fabric directly next to where you initially pushed the needle up.
    • Pull the thread taut, until the button lays flat on the fabric.
  10. Sew a Button: passo 10, imagem 1 %32 Sew a Button: passo 10, imagem 2 %32 Sew a Button: passo 10, imagem 3 %32
    • Push the needle back up through the backside of the fabric, directly next to the original knot
    • Work the needle up through one of the two remaining holes without thread.
    • Pull the thread taut.
  11. Sew a Button: passo 11, imagem 1 %32 Sew a Button: passo 11, imagem 2 %32 Sew a Button: passo 11, imagem 3 %32
    • Go back through the last remaining empty hole on the button.
    • Go back down through the fabric, as close as possible to the other two threads.
  12. Sew a Button: passo 12, imagem 1 %32 Sew a Button: passo 12, imagem 2 %32 Sew a Button: passo 12, imagem 3 %32
    • Drive the needle back up through the underside of the fabric and into the first hole that you threaded.
  13. Sew a Button: passo 13, imagem 1 %32 Sew a Button: passo 13, imagem 2 %32
    • Go back down through the second hole, directly across from the hole you just came up through.
    • Pull taut.
  14. Sew a Button: passo 14, imagem 1 %32 Sew a Button: passo 14, imagem 2 %32 Sew a Button: passo 14, imagem 3 %32
    • Push the needle up through the third hole again.
    • Pull it taut.
    • Push the needle down through the fourth hole and pull it taut.
    • Repeat steps 12-14 of this guide one more time, then proceed.
  15. Sew a Button: passo 15, imagem 1 %32 Sew a Button: passo 15, imagem 2 %32 Sew a Button: passo 15, imagem 3 %32
    • You have sewn in the button. Now you need a knot to keep the button in place.
    • Push the needle through the loops of thread on the underside of the fabric. Be careful not to catch the fabric.
  16. Sew a Button: passo 16, imagem 1 %32 Sew a Button: passo 16, imagem 2 %32
    • Leave some slack in the thread and draw the needle through the loop created by the slack.
    • Pull the thread taut, forming a knot.
    • Repeat steps 15 and 16 one more time to add a second knot.
  17. Sew a Button: passo 17, imagem 1 %32 Sew a Button: passo 17, imagem 2 %32
    • Clip the excess thread off.
    • Check your button for stability.
Linha de Chegada
58 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.977 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.867 guias
5Comentários do guia
What helps after the last step 14 is to wrap the thread around and around a few times underneath the button itself (binding all the threads together) and making one last pass through the cloth before the final knot. This makes the repair much more durable.
mccreerydennis - Responder
The wrapping below the button is not only more durable, but is actually frequently used when replacing buttons on blazers, sport coats, and the like as a protection from friction as the garment moves and shifts while being worn.
Matt - Responder
Wrapping the threads underneath the button to create a shank is useful for coat buttons where the fabric is thick and you don’t want the fabric to pucker. As noted, it adds durability to the button attachment. On a shirt collar, as seen here, it would create too much bulk where you need the button to lie quite flat, so this method is quite sufficient.
Jonathan Wells - Responder
Thanks Jonathan. Great insight.
Louie Leung - Responder
Parfait, mon pantalon est comme neuf :)
Brendan - Responder
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 31
Últimos 30 dias: 174
Ao todo: 17,941
