Introdução
Ir para o passo 1 ↓This guide will show you how to replace an old light switch wall plate (also called a faceplate) with a screwless one. Reasons to replace faceplates include but are not limited to:
- Switching from a regular wall plate to a more modern-looking screwless wall plate.
- Change of color of older wall plates that happens with the passage of time.
- Damage to the wall plate due to an accident or incorrect use.
Caution: Before beginning this guide, turn the light switch off and turn off power to the switch at the circuit breaker.
O que você precisa
You can follow this guide to replace a power outlet faceplate as the procedure is essentially the same.
7 outras pessoas executaram este guia.
