Samsung Series 9 NP900X3A RAM Replacement
Introdução
Vá para o passo 1Random Access Memory, or RAM (pronounced as ramm), is the physical hardware inside a computer that temporarily stores data, serving as the computer's "working" memory. It it held in by 2 clips on the sides of the unit, and will pop upward when released.
O que você precisa
Ferramentas
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
To insert the replacement RAM unit, follow these instructions in reverse. If RAM unit replacement does not solve your issue, you may have a defective motherboard.
4 outras pessoas executaram este guia.
