Samsung Series 9 NP900X3A Laptop Battery Replacement
Introdução
Vá para o passo 1If your computer is no longer holding a charge or is dying quickly without a charger, then you should replace the battery. This guide will help you replace the battery.
O que você precisa
Peças
Ferramentas
Exibir mais…
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
Uma outra pessoa concluiu este guia.
2 comentários
Where’s the best place to purchase an original replacement battery for this model: NP900X3A
email:
Best Email: Only related to this product SAMSUNG Model: NP900X3A.
cotodecaza@gmail.com
Thank You,
Giancarlo
