Ir para o conteúdo principal
Samsung SCH-U340 Internal Antenna Replacement
David Gomez
David Gomez e 7 outros colaboradores
Última atualização em May 31, 2018
15 - 20 minutos
Moderada
Ferramentas incorretas
A step by step guide to removing and replacing the Samsung SCH U340's internal antennae.
O que você precisa
Ferramentas
  1. Samsung SCH-U340 Internal Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Internal Antenna Replacement: passo 2, imagem 1 %32
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Internal Antenna Replacement: passo 3, imagem 1 %32
    • Set the battery aside.
  4. Samsung SCH-U340 Internal Antenna Replacement, Lower Casing: passo 4, imagem 1 %32
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Internal Antenna Replacement: passo 5, imagem 1 %32 Samsung SCH-U340 Internal Antenna Replacement: passo 5, imagem 2 %32
    • Use a spudger to pry the back assembly off of the device.
  6. Samsung SCH-U340 Internal Antenna Replacement, Internal Antenna: passo 6, imagem 1 %32
    • On the bottom casing, there should be a single metal screw holding the antennae in. Remove this screw.
  7. Samsung SCH-U340 Internal Antenna Replacement: passo 7, imagem 1 %32 Samsung SCH-U340 Internal Antenna Replacement: passo 7, imagem 2 %32
    • Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards.
Conclusão
David Gomez
Membro desde: 01/21/10
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 3-21, Maness Winter 2010 Membro de Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,233
