Ir para o conteúdo principal
Samsung PL20 LCD Replacement
oldturkey03
oldturkey03 e 4 outros colaboradores
Última atualização em 12 de nov de 2020
Nenhuma estimativa
Moderado
Fotos de ação
Despedaçar
Guia colaborativo
Introdução
Ir para o passo 1
Here is a PL20 that has a broken LCD, as well as some other issues. The repair is straight forward. The only tools used were a Phillips screwdriver and a plastic opening tool, which is optional. This camera was actually fun to work on; it was easy and took no time at all.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Samsung PL20 LCD Replacement, LCD: passo 1, imagem 1 %32 Samsung PL20 LCD Replacement, LCD: passo 1, imagem 2 %32 Samsung PL20 LCD Replacement, LCD: passo 1, imagem 3 %32
    • Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
    • Remove the battery and the memory card from the device, if so equipped.
    • Remove the two screws on the left side.
  2. Samsung PL20 LCD Replacement: passo 2, imagem 1 %32 Samsung PL20 LCD Replacement: passo 2, imagem 2 %32 Samsung PL20 LCD Replacement: passo 2, imagem 3 %32
    • Remove one screw from the bottom
    • Remove the two screws on the right side.
    • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
  3. Samsung PL20 LCD Replacement: passo 3, imagem 1 %32 Samsung PL20 LCD Replacement: passo 3, imagem 2 %32 Samsung PL20 LCD Replacement: passo 3, imagem 3 %32
    • Once the back of the case is removed, the LCD becomes immediately visible.
    • Remove the LCD from its holder to gain access to the connector.
    • Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
Conclusão
6 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
oldturkey03
Membro desde: 09/29/10
822.880 Reputação
Autoria de 122 guias
1Comentário do guia
Great help! Screen replaced no problem. Thank you
EE61 - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 3,835
