Samsung NP540U3C-A02UB Speaker Replacement
Introdução
Ir para o passo 1This guide covers how to replace the speakers for the Samsung Series 5 NP540U3C-A02UB.
The speakers are responsible for playing audio for the device. The speakers may need to be replaced if no sound is coming from the laptop, or sound has bad quality. If the sound on your laptop is not working adequately, see our troubleshooting guide for possible causes and solutions before attempting to replace the speakers.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Remove the following screws holding the case together:
6x 4mm Phillips #00 screws.
3x 6mm Phillips #00 screws.
Using the plastic opening tool, gently release the connector for the speaker(s) you are replacing.
