Samsung NP540U3C-A02UB Hard Drive Replacement
Introdução
Ir para o passo 1This guide covers how to replace the hard drive for the Samsung Series 5 NP540U3C-A02UB.
The hard drive stores the device's data and ensures that is kept, even when power is disconnected. More importantly, the operating system is run from the hard drive. The hard drive may need to be replaced if either data or the operating system appears to be corrupted. If the device is running slowly, see our troubleshooting guide for possible causes and solutions before attempting to replace the hard drive.
If you choose to restore your previous operating system onto the replacement hard drive to resume normal operation, ensure that the replacement has enough storage to contain all of your old files. This device accepts 2.5" SATA hard drives (HDD), or 2.5" SATA solid-state drives (SSD). Solid-state drives will boot and operate much faster than hard drives.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Uma outra pessoa concluiu este guia.
