Ir para o conteúdo principal
Samsung Galaxy J3 Emerge Screen Replacement
PJ Yebisu
PJ Yebisu e 4 outros colaboradores
Última atualização em March 6, 2019
5 minutos
Fácil
Introdução
Ir para o passo 1
Screen Replacement guide for a Samsung Galaxy J3 Emerge Model SM-J327P. To heat the adhesive up that holds the screen on the phone, use a hairdryer. The screen might need replacing if the display is unresponsive or if the phone won't turn on. The screen can be replaced if the original cracks.
O que você precisa
Ferramentas
Exibir mais…
  1. Samsung Galaxy J3 Emerge Screen Replacement, Screen: passo 1, imagem 1 %32 Samsung Galaxy J3 Emerge Screen Replacement, Screen: passo 1, imagem 2 %32 Samsung Galaxy J3 Emerge Screen Replacement, Screen: passo 1, imagem 3 %32
    • Heat up the edges of the screen with a hair dryer.
    • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
    • Work the iFixit Opening Tools around the whole screen to break the glue.
  2. Samsung Galaxy J3 Emerge Screen Replacement: passo 2, imagem 1 %32 Samsung Galaxy J3 Emerge Screen Replacement: passo 2, imagem 2 %32
    • Lift the screen up from the bottom.
    • The screen could crack when lifting it up.
    • Pry the gray cover open.
  3. Samsung Galaxy J3 Emerge Screen Replacement: passo 3, imagem 1 %32 Samsung Galaxy J3 Emerge Screen Replacement: passo 3, imagem 2 %32
    • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
Conclusão
7 outras pessoas executaram este guia.
PJ Yebisu
Membro desde: 01/24/19
271 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S19-G2, White Winter 2019 Membro de Cal Poly, Team S19-G2, White Winter 2019
CPSU-WHITE-W19S19G2
4 Membros
Autoria de 5 guias
2Comentários do guia
I was using my J3 Emerge last night and all of a sudden the screen just went blank. At first, I could press the power button and I would see the Samsung logo for a split second but now it doesn’t do that. You can tell it is trying to turn on because you can see it change from black to a blue like color. I thought it might be the battery so I took it to a store today to buy a new one but he said that wasn’t the problem. It is charging but I just can’t see anything. Do you think I need a new LCD screen or is it something else? Thank you!
theleachs - Responder
Gostei da aula parabens muito gratificante.
athoscost - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Ao todo: 3,204
