Ir para o conteúdo principal
Samsung Galaxy Gear Battery Replacement
Edward Yi
Edward Yi e 7 outros colaboradores
Última atualização em September 9, 2020
7 minutos
Fácil
Introdução
Ir para o passo 1
Note: This guide is a continuation off of the display housing removal guide. It is crucial that you follow and complete the prerequisite guide step-by-step.
Use this guide to easily replace a faulty battery or insert a fresh new battery for a longer- lasting, more reliable Samsung Galaxy Gear watch.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Samsung Galaxy Gear Battery Replacement, Display Housing: passo 1, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Battery Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Battery Replacement: passo 3, imagem 1 %32 Samsung Galaxy Gear Battery Replacement: passo 3, imagem 2 %32
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
    The screws Phillips are PH000 (triple Zero)
    harnelbe - Responder
  4. Samsung Galaxy Gear Battery Replacement, Battery: passo 4, imagem 1 %32 Samsung Galaxy Gear Battery Replacement, Battery: passo 4, imagem 2 %32
    • After separating the LCD/motherboard from the actual watch itself, the watch should be in two separate pieces.
    • You will only need the watch/strap component so you can set aside the LCD/motherboard component.
  5. Samsung Galaxy Gear Battery Replacement: passo 5, imagem 1 %32 Samsung Galaxy Gear Battery Replacement: passo 5, imagem 2 %32 Samsung Galaxy Gear Battery Replacement: passo 5, imagem 3 %32
    • Look for the metal bracket that covers and secures the battery in place.
    • Loosen the bracket by prying underneath the metal plating with the plastic opening tool. Remove the bracket and set it to the side.
    • The battery should now be exposed.
  6. Samsung Galaxy Gear Battery Replacement: passo 6, imagem 1 %32 Samsung Galaxy Gear Battery Replacement: passo 6, imagem 2 %32 Samsung Galaxy Gear Battery Replacement: passo 6, imagem 3 %32
    • Notice the leads attached to the base of the watch. You will need to remove this before you pull the battery out.
    • Using the plastic opening tool, pry underneath the leads and disconnect it from the back of the watch.
    • Slowly tug on the "PULL" tag and remove the battery from the watch.
Conclusão
11 outras pessoas executaram este guia.
Edward Yi
Membro desde: 04/11/16
424 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 1-9, Maness Spring 2016 Membro de Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 Membros
Autoria de 7 guias
4 comentários
WHERE DO I GET A NEW bATTERY & THE TOOLS; IS A COMPLETE KIT AVAILABLE?
rbilello - Responder
where do I get the battery & tools
steve ellis - Responder
“Parts
No parts required.”
I think a battery is required!
cyberjoe3d - Responder
Thank you very much
Adam P NYC
bori0916adam - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 24
Ao todo: 13,613
