Ir para o conteúdo principal
Samsung Galaxy Book Pro 360 15" SSD Replacement
Spencer Day
Spencer Day e 2 outros colaboradores
Última atualização em July 11, 2024
15 - 20 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to replace one or both of the SSDs in your Galaxy Book Pro 360 15" laptop.
Before you begin, refer to the Samsung PC Repair Guide for safety information.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Access the rubber feet: passo 1, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Access the rubber feet: passo 1, imagem 2 %32
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rubber feet: passo 2, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rubber feet: passo 2, imagem 2 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rubber feet: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the rear case: passo 3, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the rear case: passo 3, imagem 2 %32
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
  4. Samsung Galaxy Book Pro 360 15" SSD Replacement, Insert an opening pick: passo 4, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Insert an opening pick: passo 4, imagem 2 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Insert an opening pick: passo 4, imagem 3 %32
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" SSD Replacement, Release the clips: passo 5, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Release the clips: passo 5, imagem 2 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Release the clips: passo 5, imagem 3 %32
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rear case: passo 6, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rear case: passo 6, imagem 2 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rear case: passo 6, imagem 3 %32
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
    Hey, be carefull with the screw attachment between the lid and the chassie. They brake away easily if tightenend too much.
    Sora [___] - Responder
  7. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the battery connector's tape: passo 7, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the battery connector's tape: passo 7, imagem 2 %32
    • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
    • Set the tape aside. You'll reuse it during reassembly.
  8. Samsung Galaxy Book Pro 360 15" SSD Replacement, Disconnect the battery: passo 8, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Disconnect the battery: passo 8, imagem 2 %32
    • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
    • Gently pry up and disconnect the battery connector from its socket.
  9. Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the SSD: passo 9, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the SSD: passo 9, imagem 2 %32
    • Use a Phillips screwdriver to remove the 3.5 mm screw securing the left SSD.
  10. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the SSD: passo 10, imagem 1 %32 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the SSD: passo 10, imagem 2 %32
    • Pull the left SSD out of its socket and remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
  11. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the right SSD: passo 11, imagem 1 %32
    • If you have a right SSD installed, repeat the removal procedure on it.
    spot on thanks for the great pics and info much apprecited
    Paddy Farrell - Responder
Conclusão
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Spencer Day
Membro desde: 09/14/22
95.787 Reputação
Autoria de 662 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.583 guias
Um comentário
Hello! The Galaxy Book3 360 not the Pro version, also has two coolers? Or only one?
Erick Giacomazza - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 38
Últimos 30 dias: 224
Ao todo: 4,539
