Ir para o conteúdo principal
Samsung Galaxy A51 Battery Replacement
Adriana Zwink
Adriana Zwink e 3 outros colaboradores
Última atualização em May 24, 2024
45 minutos - 2 horas
Moderada
Guia em destaque
Use this guide to replace a worn-out or dead battery in your Galaxy A51.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Samsung Galaxy A51 Battery Replacement, Samsung Galaxy A51 SIM Tray Removal: passo 1, imagem 1 %32 Samsung Galaxy A51 Battery Replacement, Samsung Galaxy A51 SIM Tray Removal: passo 1, imagem 2 %32 Samsung Galaxy A51 Battery Replacement, Samsung Galaxy A51 SIM Tray Removal: passo 1, imagem 3 %32
    • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Samsung Galaxy A51 Battery Replacement, Back Cover: passo 2, imagem 1 %32
    • Before beginning this procedure, completely power off your phone.
    • Prepare an iOpener and apply it to the back cover to soften the adhesive.
    • The adhesive of the Samsung Galaxy A51 is very strong. You can use a hair dryer or a heat gun if you aren't able to open the device with the iOpener.
    • Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy A51 Battery Replacement: passo 3, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 3, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 3, imagem 3 %32
    • Insert the tip of an opening pick between the frame and the back cover at the bottom of the phone near the USB-C port.
    • If you can't get between the back cover and midframe with your opening pick, you can use a suction handle or strong tape to pull up the back cover to create a gap.
    • Slide the opening pick to the bottom right corner and leave it there.
  4. Samsung Galaxy A51 Battery Replacement: passo 4, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 4, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 4, imagem 3 %32
    • Insert a second opening pick and slide it from the bottom right corner to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A51 Battery Replacement: passo 5, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 5, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 5, imagem 3 %32
    • Insert a third opening pick under the bottom left corner of the back cover.
    • If you have any trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick along the left edge of the phone.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A51 Battery Replacement: passo 6, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 6, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 6, imagem 3 %32
    • Insert a fourth opening pick under the top left corner of the back cover near the camera.
    • Slide the tip of the opening pick along the top edge of the phone to the right corner to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A51 Battery Replacement: passo 7, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 7, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 7, imagem 3 %32
    • With opening picks in all four corners, insert a fifth and final opening pick under the top right corner of the back cover.
    • Slide the tip of the opening pick along the right edge of the phone to the bottom right corner to cut the remaining adhesive.
  8. Samsung Galaxy A51 Battery Replacement: passo 8, imagem 1 %32
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Samsung Galaxy A51 Battery Replacement, Midframe: passo 9, imagem 1 %32
    • Remove the thirteen 3 mm Phillips #00 screws securing the midframe.
  10. Samsung Galaxy A51 Battery Replacement: passo 10, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 10, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 10, imagem 3 %32
    • The midframe is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the bottom of the phone near the charge port.
    • Slide the opening pick to the left bottom corner to release the plastic clips.
    • Slide the opening pick to the bottom right corner to release the rest of the bottom plastic clips.
  11. Samsung Galaxy A51 Battery Replacement: passo 11, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 11, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 11, imagem 3 %32
    • Continue sliding the opening pick on the right side of your phone until all plastic clips on the right side are released.
  12. Samsung Galaxy A51 Battery Replacement: passo 12, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 12, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 12, imagem 3 %32
    • Slide the opening pick along the top edge to release the top plastic clips.
  13. Samsung Galaxy A51 Battery Replacement: passo 13, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 13, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 13, imagem 3 %32
    • Slide the opening pick from the top left corner to the bottom left corner to release the left side's plastic clips.
  14. Samsung Galaxy A51 Battery Replacement: passo 14, imagem 1 %32
    • Remove the midframe.
  15. Samsung Galaxy A51 Battery Replacement, Battery Disconnect: passo 15, imagem 1 %32 Samsung Galaxy A51 Battery Replacement, Battery Disconnect: passo 15, imagem 2 %32
    • Use the flat end of a spudger to disconnect the battery by prying the connector straight up from its socket.
  16. Samsung Galaxy A51 Battery Replacement, Battery: passo 16, imagem 1 %32 Samsung Galaxy A51 Battery Replacement, Battery: passo 16, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable from the motherboard.
  17. Samsung Galaxy A51 Battery Replacement: passo 17, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 17, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable from the daughterboard.
    • Remove the interconnect cable.
  18. Samsung Galaxy A51 Battery Replacement: passo 18, imagem 1 %32
    • Apply an iOpener for 2-3 minutes to the battery to loosen the adhesive beneath the battery. Apply the iOpener for 2-3 minutes.
    • You may need to repeat this procedure several times during the battery removal.
  19. Samsung Galaxy A51 Battery Replacement: passo 19, imagem 1 %32 Samsung Galaxy A51 Battery Replacement: passo 19, imagem 2 %32 Samsung Galaxy A51 Battery Replacement: passo 19, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert a plastic card underneath the bottom edge of the battery.
    • Carefully slide it underneath the battery to loosen the adhesive.
  20. Samsung Galaxy A51 Battery Replacement: passo 20, imagem 1 %32
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
33 outras pessoas executaram este guia.
Adriana Zwink
Membro desde: 12/18/19
56.450 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.468 guias
3 comentários
C'est vraiment génial
MADRINO Tago - Responder
A51 5g smartphone?
kimgi0701 - Responder
Creo que entre los utiles que hacen falta más el precio de la batería, casi sale más conveniente llevarlo a un servicio técnico autorizado, que además te dan garantia de la reparación. Al menos esa es mi opinión después de hacer cuentas.
De todas formas una gran explicación y muy bien traducido al español.
Muchísimasgracias.
5 estrellas para la descripción del trabajo.
Lástima que debería cambiar tambien el vibrador que no me funciona y no he encontrado como hacerlo.
Pepe Serrano - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 35
Últimos 7 dias: 300
Últimos 30 dias: 1,209
Duração total: 87,508
