Ir para o conteúdo principal
Samsung Eternity Motherboard Replacement
Kevin Huang
Kevin Huang e 8 outros colaboradores
Última atualização em January 13, 2025
15 - 25 minutos
Moderada
Ferramentas incorretas
Precisa de mais images
Melhor Introdução
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's motherboard.
O que você precisa
Ferramentas
Exibir mais…
    • Remove the back battery cover.
  1. Samsung Eternity Motherboard Replacement: passo 2, imagem 1 %32
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Motherboard Replacement: passo 3, imagem 1 %32
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Motherboard Replacement: passo 4, imagem 1 %32 Samsung Eternity Motherboard Replacement: passo 4, imagem 2 %32
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Motherboard Replacement: passo 6, imagem 1 %32 Samsung Eternity Motherboard Replacement: passo 6, imagem 2 %32 Samsung Eternity Motherboard Replacement: passo 6, imagem 3 %32
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Motherboard Replacement: passo 7, imagem 1 %32
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Motherboard Replacement: passo 8, imagem 1 %32
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Motherboard Replacement: passo 9, imagem 1 %32 Samsung Eternity Motherboard Replacement: passo 9, imagem 2 %32 Samsung Eternity Motherboard Replacement: passo 9, imagem 3 %32
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Motherboard Replacement: passo 10, imagem 1 %32
    • You have successfully removed the motherboard from the phone.
Conclusão
Kevin Huang
Membro desde: 04/20/11
11 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-11, Regan Spring 2011 Membro de Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,345
