Ir para o conteúdo principal
Samsung Eternity Antenna/Speaker Replacement
Matthew Kidd
Matthew Kidd e 6 outros colaboradores
Última atualização em June 14, 2024
15 - 20 minutos
Moderada
Ferramentas incorretas
Imagens inconsistentes
Melhor Introdução
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's antenna/speaker module.
O que você precisa
Ferramentas
Exibir mais…
    • Remove the back battery cover.
  1. Samsung Eternity Antenna/Speaker Replacement: passo 2, imagem 1 %32
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Antenna/Speaker Replacement: passo 3, imagem 1 %32
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Antenna/Speaker Replacement: passo 4, imagem 1 %32 Samsung Eternity Antenna/Speaker Replacement: passo 4, imagem 2 %32
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Antenna/Speaker Replacement, Antenna/Speaker: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Pop the antenna plug off of its socket with a pair of metal tweezers.
  5. Samsung Eternity Antenna/Speaker Replacement: passo 6, imagem 1 %32
    • Peel off the Identification sticker.
  6. Samsung Eternity Antenna/Speaker Replacement: passo 7, imagem 1 %32
    • Peel the button sensor on the side of the motherboard off of the case.
  7. Samsung Eternity Antenna/Speaker Replacement: passo 8, imagem 1 %32
    • Pop the speaker plug out of its socket.
  8. Samsung Eternity Antenna/Speaker Replacement: passo 9, imagem 1 %32
    • Pry the antenna/speaker component out of its casing. You need to use a little force to get the piece to pop out.
  9. Samsung Eternity Antenna/Speaker Replacement: passo 10, imagem 1 %32
    • You will now be able to replace the antenna/speaker module.
Conclusão
Matthew Kidd
Membro desde: 04/20/11
70 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-11, Regan Spring 2011 Membro de Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,902
