SKARSTA Desk O-ring Replacement
Introdução
Vá para o passo 1Over time, the O-ring in your manual standing desk may wear out, causing difficulties in height adjustment. This guide will walk you through the process of replacing the O-ring on the IKEA SKARSTA manual standing desk (model # 004.585.55), ensuring your desk continues to function smoothly.
The O-ring plays a critical role in the desk's height adjustment mechanism. A worn-out O-ring can lead to uneven or difficult adjustments.
Before starting, ensure the desk is clear of items. In Steps 3 and 11, you may want assistance to lift the table off and back on the table stand.
O que você precisa
Peças
Ferramentas
Position yourself so you can comfortably reach underneath the desk. This might involve kneeling or sitting next to/under the desk.
Remove the two 15.2 mm Phillips #2 screws connecting the crank to the table.
Remove the eight 15.2 mm Phillips #2 screws connecting the table to the legs.
Congratulations! The repair is complete.
