Ir para o conteúdo principal
Remington MB4040 Battery Replacement
Cameron Carnahan
Cameron Carnahan e 3 outros colaboradores
Última atualização em February 19, 2025
10 - 15 minutos
Difícil
The battery is where the charge is stored and allows the motor to run. The battery is connected to the motor through the motherboard.
O que você precisa
Ferramentas
Exibir mais…
  1. Remington MB4040 Battery Replacement, Remove Blade Assembly: passo 1, imagem 1 %32 Remington MB4040 Battery Replacement, Remove Blade Assembly: passo 1, imagem 2 %32 Remington MB4040 Battery Replacement, Remove Blade Assembly: passo 1, imagem 3 %32
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Battery Replacement, Remove Back Cover Hardware: passo 2, imagem 1 %32 Remington MB4040 Battery Replacement, Remove Back Cover Hardware: passo 2, imagem 2 %32
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Battery Replacement, Remove Front Cover Hardware: passo 3, imagem 1 %32 Remington MB4040 Battery Replacement, Remove Front Cover Hardware: passo 3, imagem 2 %32 Remington MB4040 Battery Replacement, Remove Front Cover Hardware: passo 3, imagem 3 %32
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Battery Replacement, Front Cover (cont.): passo 4, imagem 1 %32 Remington MB4040 Battery Replacement, Front Cover (cont.): passo 4, imagem 2 %32
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Battery Replacement, Blade Button Removal: passo 5, imagem 1 %32 Remington MB4040 Battery Replacement, Blade Button Removal: passo 5, imagem 2 %32
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Battery Replacement, Remove Motherboard: passo 6, imagem 1 %32 Remington MB4040 Battery Replacement, Remove Motherboard: passo 6, imagem 2 %32
    • Remove the four 9.0 mm PH00 screws from the motherboard.
    • Use the plastic opening tool to remove the motherboard from its housing.
    • This can be completed with the Remington MB4040 Zoom Wheel Replacement installed or removed. Just adjust the zoom wheel until it no longer covers the motherboard.
  7. Remington MB4040 Battery Replacement, Remove Battery: passo 7, imagem 1 %32 Remington MB4040 Battery Replacement, Remove Battery: passo 7, imagem 2 %32 Remington MB4040 Battery Replacement, Remove Battery: passo 7, imagem 3 %32
    • Remove the thermal switch from the battery by using the spudger to pry it from the adhesive.
    • Remove the battery by desoldering the battery from the motherboard.
    • Soldering tabs hold the battery onto the motherboard.
Conclusão
23 outras pessoas executaram este guia.
Cameron Carnahan
Membro desde: 01/20/15
1.082 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 1-5, Blackwell Winter 2015 Membro de USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
Membros da 3
Autoria de 14 guias
13 comentários
Great work - but help on where to source the battery would be good too :)
Matt Purnell - Responder
It's available as a generic - it's a '14500' Li-Ion battery, 3.7V - typically 750-800mAh. Dimensions: 50mm x 14mm (diameter).
I have seen two types of these batteries: protected and unprotected. Which type do we need?
Amaury C -
You did everyrhing except the most important part to me
How did you unsolder the battery, and solder the new battery?
I was going to buy the tools from the local store but realized i don't know how to appropriately unsolder/solder battery tabs.
Non the less you are the only one who made such explanation, thank you.
Rakan - Responder
If you happen to lose the two springs, you can cut off 2 pieces from the spring of a pen :P
Merry Trimming & A Happy New Beard !
Mads Larsen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 91
Últimos 30 dias: 274
Duração total: 38,948
