Ir para o conteúdo principal
Remington MB4040 Zoom Wheel Replacement
O que você precisa
  1. Remington MB4040 Zoom Wheel Replacement, Remove Blade Assembly: passo 1, imagem 1 %32 Remington MB4040 Zoom Wheel Replacement, Remove Blade Assembly: passo 1, imagem 2 %32 Remington MB4040 Zoom Wheel Replacement, Remove Blade Assembly: passo 1, imagem 3 %32
    • Press the black button below the blade to remove the blade.
    Pergunte ao FixBot
    Comentar
  2. Remington MB4040 Zoom Wheel Replacement, Remove Back Cover Hardware: passo 2, imagem 1 %32 Remington MB4040 Zoom Wheel Replacement, Remove Back Cover Hardware: passo 2, imagem 2 %32
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
    Pergunte ao FixBot
    Comentar
  3. Remington MB4040 Zoom Wheel Replacement, Remove Front Cover Hardware: passo 3, imagem 1 %32 Remington MB4040 Zoom Wheel Replacement, Remove Front Cover Hardware: passo 3, imagem 2 %32 Remington MB4040 Zoom Wheel Replacement, Remove Front Cover Hardware: passo 3, imagem 3 %32
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
    Pergunte ao FixBot
    Comentar
  4. Remington MB4040 Zoom Wheel Replacement, Front Cover (cont.): passo 4, imagem 1 %32 Remington MB4040 Zoom Wheel Replacement, Front Cover (cont.): passo 4, imagem 2 %32
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
    Pergunte ao FixBot
    Comentar
  5. Remington MB4040 Zoom Wheel Replacement, Blade Button Removal: passo 5, imagem 1 %32 Remington MB4040 Zoom Wheel Replacement, Blade Button Removal: passo 5, imagem 2 %32
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
    Pergunte ao FixBot
    Comentar
  6. Remington MB4040 Zoom Wheel Replacement, Remove screws attaching the zoom wheel: passo 6, imagem 1 %32 Remington MB4040 Zoom Wheel Replacement, Remove screws attaching the zoom wheel: passo 6, imagem 2 %32
    • Remove the two 11.0 mm PH00 screws that attach the zoom wheel to the plastic housing.
    Pergunte ao FixBot
    Comentar
  7. Remington MB4040 Zoom Wheel Replacement, Remove Zoom Wheel Assembly: passo 7, imagem 1 %32 Remington MB4040 Zoom Wheel Replacement, Remove Zoom Wheel Assembly: passo 7, imagem 2 %32 Remington MB4040 Zoom Wheel Replacement, Remove Zoom Wheel Assembly: passo 7, imagem 3 %32
    • Remove zoom wheel assembly from housing using fingers.
    • Gently remove zoom wheel assembly because the red and black wires are attached and can easily be broken.
    • This assembly also houses the motor.
    • Remove the small black piece of plastic surrounding the zoom wheel. This will be referred to as the slider.
    • When reassembling, make sure the pins on the slider are aligned inside the grooves of the wheel.
    Pergunte ao FixBot
    Comentar
  8. Remington MB4040 Zoom Wheel Replacement, Wheel removal: passo 8, imagem 1 %32 Remington MB4040 Zoom Wheel Replacement, Wheel removal: passo 8, imagem 2 %32 Remington MB4040 Zoom Wheel Replacement, Wheel removal: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • A pin holds the wheel in place. Using a spudger (preferable metal) and a pair of pliers or tweezers remove the pin to unseat the wheel.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-5, Blackwell Winter 2015 Membro de USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 23
Ao todo: 3,689
