Ir para o conteúdo principal
PowerA Fusion Controller For Xbox One Buttons Replacement
Andrea
Andrea e 4 outros colaboradores
Última atualização em December 15, 2023
20 minutos
Moderada
Buttons are a crucial part of any controller. However, after extended use, whether regular or light, the buttons will wear down. This guide will show you how to replace the buttons on your controller. Please note that this guide is for replacing the buttons, not the circuitry attached to them. If the buttons are acting strange, for instance reading a tap as a double tap, this guide may not help.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: passo 1, imagem 1 %32 PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: passo 1, imagem 2 %32 PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: passo 1, imagem 3 %32
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Buttons Replacement: passo 2, imagem 1 %32 PowerA Fusion Controller For Xbox One Buttons Replacement: passo 2, imagem 2 %32
    • Remove the (2) two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
    Would have been a better guide if you actually used a power a fusion controller.
    This is just a normal power a controller.
    Fusion has detachable cable and 4 detachable paddles on the back.
    Lol
    Qyuubix - Responder
  3. PowerA Fusion Controller For Xbox One Buttons Replacement: passo 3, imagem 1 %32 PowerA Fusion Controller For Xbox One Buttons Replacement: passo 3, imagem 2 %32 PowerA Fusion Controller For Xbox One Buttons Replacement: passo 3, imagem 3 %32
    • Remove the (5) five 9.2mm screws with a JIS #1 screwdriver.
    • Lift the motherboard and let it hang.
  4. PowerA Fusion Controller For Xbox One Buttons Replacement: passo 4, imagem 1 %32 PowerA Fusion Controller For Xbox One Buttons Replacement: passo 4, imagem 2 %32
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Put the motherboard aside.
  5. PowerA Fusion Controller For Xbox One Buttons Replacement: passo 5, imagem 1 %32 PowerA Fusion Controller For Xbox One Buttons Replacement: passo 5, imagem 2 %32
    • Remove the buttons.
  6. PowerA Fusion Controller For Xbox One Buttons Replacement: passo 6, imagem 1 %32 PowerA Fusion Controller For Xbox One Buttons Replacement: passo 6, imagem 2 %32
    • Go back to the motherboard, and remove the buttons' gasket with a tweezler.
    What do you do after you remove the button gasket
    AcridAssassin - Responder
    Do the buttons come with the gasket? Also the buttons are for an Xbox One controller. Does that mean they are compatible?
    Alexi Macias - Responder
Conclusão
9 outras pessoas executaram este guia.
Andrea
Membro desde: 09/26/17
644 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S14-G4, Boczar Fall 2017 Membro de USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
Membros da 4
Autoria de 5 guias
2 comentários
Okay so what do you do if by any chance one of the links that are sawdered to the mother board for the D Pad Connection cable breaks… Then what? How would I go about fixing that????
Heather Jesse - Responder
is there a guide to clean the bumpers out? my RB became less consistent and i'm hoping it's just because they're gunked up
urmum - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 72
Duração total: 19,228
